Fanuc 18i-TB program from memory card
cnczack
Sep 14, 2020
We have come to the conclusion that the rs232 port is bad for this machine. We purchased a PCMCIA card and a 128mb compact flash to run programs from until we fix the issue.
The card is already in FAT format. I’m not sure if I’m doing something wrong trying to pull a program in. So this is what I do…
Channel 4
Edit
Oprt
Read
Exec
99 memory card error
If I try shutting the machine off. Holding in the right two soft keys. I go down to format card but it just says “formatting card”. It never finishes. I let it run for an hour without completing. I ordered a 32mb card as well which won’t be in until Tuesday. Is this the correct process for trying to pull in programs? I tried this on 3 other 18 controllers to format the card but none worked. Any suggestions?
sinha
Sep 25, 2010
india
Try this ...
EDIT mode on MOP
PROG key on MDI
Next menu soft key >
CARD soft key
Does it show the directory of the card?
gregormarwick
Feb 7, 2007
Aberdeen, UK
I used the card on my 18i-TB for years before I connected it to ethernet.
I never got the card to work with the channel/read process.
You need to load from the card directory as Sinha describes above.
EnginCycles
Aug 11, 2008
Philadelphia,PA
My Fanuc control will only run 64 and under from a certain brand no matter what type of formatting is done. Also it can on occasion corrupt a card and deem it useless. They are very sensitive.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
IME, one can always use SRAM based PCMCIA cards with 100% reliability. There actually is a Fanuc spec for flash cards that requires use of a certain series of Intel Flash memory chips. Unless one uses that specific type, compatibility is not certain.
gregormarwick
Feb 7, 2007
Aberdeen, UK
I have Sandisk 128mb compact flash cards with a pcmcia adapter (generic and Fanuc adapters).
They work in the 18i-TB and the Oi-TC/D that I have, I don't think there is any hardware compatibility issue.
However, as I noted above, I could not get it to work by setting the channel and reading the programs in on the 18i-TB. It will happily run a subprogram from the card using M98, but will not read a program directly.
Loading a program from the card, at least on my 18i-TB, requires (AFAICT) loading by reading the file from the card directory*. Same with ethernet, it will not load a program with the READ softkey regardless of how the channel is set, and you have to read the file from the ETHERNET > EMBED > HOST directory screen.
I haven't had the need to try M98 over ethernet yet.
Of course it's possible that I was doing something wrong when I was trying to get this to work, but I don't think so.
* Edit mode, PROG > DIR > press the right softkey until you see CARD and press it > F SET # > O SET # > EXEC. Stupid long winded, but the only way I could ever get it to work.
cnczack
Sep 14, 2020
This worked!! i appreciate it so much!
