Hi,
I usually just look here to find the help I need but this time I cant find the answer.
I have a 96 Excel 5T18 with 21m Fanuc control. It works great usually, but I shut it down for 2 wks for a medical issue and turned it back on and here is the weird problem.
It cant find the tools correctly. If I clear and reset the tools: m100 and m101. The carousel works sorta. I call T1 not adding m6 and it rotates and drops pot into change position. The pot tag is #1 that it does call up. Pot #2 called again by T2 and no M6, it calls the correct pot and moves it into change position. It continues to due this until I call T4. here it always rotates to the pot but never moves it into the change position. Machine basically hangs here. Must do M100/M101 again and rotate carousel again to get it to start at T1 again, T2 and T3, if I SKIP T4...any tool after T4 is "lost" position wise, the carousel just rotates 2 times and times out without finding the correct pot. I can reset in this spinning of the arousel and call up lets say T12 and it will hunt for it but rotates 2 revolutions and times out again.
This is repeatable after every M100/M101 sequence. I assume there is a store tool in spindle issue somewhere that has T4 stuck in it.
It does exactly the same when trying T1M6 it will change the tools up to 4 and gets "stuck" on tool 4 or hunts for any tools 5 and above.
I have tried reading everything I can find to fix this but I am baffled!!!
I appreciate any and all help.
Thanks
Thanks
