Fanuc backlash parameter
Hertz
Apr 27, 2009
Sudbury, Ontario, Canada
Good morning guys. I'm looking to correct some backlash in my CNC lathe and was looking at parameter 1851 and 1852.
Looking for guidance on how to adjust. I have .0023 inches of backlash in my X axis.
Fanuc 21i-T
Any recommendations?
Do I need to be in a program to measure the compensation or can I do it with the handwheel and a dial? That's how I'm finding out there is a couple thou backlash in the X but I'm not sure if that's the proper way.
dandrummerman21
Feb 5, 2008
MI, USA
Thats how I've always done it.
Is it that much everywhere along the x? That's a pretty big amount, but not unheard of.
I'd be suspect of the thrust bearing(s), but could be wear in the balls/nut, or a badly worn spot in one part of the screw.
angelw
Sep 10, 2010
Victoria Australia
Fanuc 21i-T
Hello Hertz,
Are you testing the amount of Backlash with the amount of Backlash compensated for via parameter set to Zero? The Total Backlash is what you're measuring, plus whatever is set for compensation in the parameters.
Compensating for Backlash via parameters doesn't get rid of the Backlash, its still there mechanically and when excessive, it should be address mechanically.
Regards,
Bill
Hertz
Apr 27, 2009
I have 0 in both x and z right now in the parameter 1851. There is .002 backlash in the X when I use a dial and the handwheel. I was just wondering if the compensation in the parameter would compensate for it if I put 2 in there.
And then I was just wondering how I would verify that it's adjusted or compensated. I realized that I may have to fix it physically, but in the intern, I was wondering if I'm forced to run it like that or if there's somewhere I can help it compensate. I appreciate the answers guys, thank you. I guess I'm still right where I was before I posted this LOL
angelw
Sep 10, 2010
Victoria Australia
Hello Hertz,
Although your machine may be configured for Imperial operation, the Backlash Compensation is in a number of 0.001mm units, specified without a period. Accordingly, for 0.002", you would input a value of 50 (50 x 0.001 = 0.05mm = 0.002")
You can check that the figure is correct using the Hand-wheel and dial indicator.
Regards,
Bill
aj
May 12, 2006
Burlington, North Carolina
The beauty of the 1851 parameter is it takes effect immediately. None of that Fanuc 'power on/power off' nonsense. So you can change it incrementally and see the changes.
aj
May 12, 2006
Hello Hertz,
The same is true for grid shift (1850) , correct? That one always gives me grief.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
Hello Hertz,
Regards,
Bill
ive got a machine with 18M, it has a comp for every "1" value you add to it, it changes it by a tenth.
Determined by whether the machine has metric or inch (imperial) pitch screws.
Hertz
Apr 27, 2009
Hello Hertz,
Regards,
Bill
Ok thanks alot. I tried putting 2 yesterday and it didn't move at all. Those makes sense why it didn't. I'll take a look again in the morning.
angelw
Sep 10, 2010
Victoria Australia
Hello Hertz,
If your machine has an Imperial Pitch Lead Screw, the number you would have to register for 0.002" is 20. Unless you're using a dial indicator with a resolution of 0.0001" you may not see any result when entering the number 2 only.
Regards,
Bill
