Thanks Bill. I think I should give more of a back story as to how this started. The battery on the Fanuc died. The machine owner had to reset the home positions for each axis. When they were done and tried to do a tool change the carousel crashed in the side of the head because the head didn't come up high enough. Thats when I got a call. I found out if you change Parameter 1241 number that would change the Z height at tool change. I changed the number to 95500 and the head went to the correct height to do the tool change. The problem is it didn’t come up high enough for the carousel to clear the tool it put away to index the carousel so it crashed the carousel.
That said to you think the initial issue is the Z axis is not homing to the correct height therefore throwing off the tool change height? Should I start by changing parameter 1241 back to the number it was?
Thanks
Duck Waddel,
The Tool Change for any Fanuc Controlled machine can be either completely carried out by the PMC, or a combination of PMC and a Macro Program; its entirely up to the MTB.
If the Backup battery died, the parameters and programs would have been lost. That being the case, if a Tool Change Macro was being used in the Tool Change process then its a wonder that the Tool Change works at all. Accordingly, it may be a case that the PMC carries out the whole tool change.
If is far more common for there to be joint effort between a Tool Change Macro and the PMC, for your type of Tool Change Magazine, but that is not to say that the value for the 2nd Z Home position isn't being used by the PMC, if the PMC is acting alone. Please describe the complete Tool Change Process so that we are on the same page. In most cases with a carousal magazine type tool changer the sequence is as follows:
1. The spindle orientates to the Tool Change Position (M19)
2. If there is a tool in the spindle, the empty magazine tool grip will grip the Spindle Tool by the Carousal moving towards the Spindle. The Z Axis will normally be at the Reference Return Position (Z Home - G28)
3. The Draw Bar pulling the Tool Holder tight in the Spindle will release its grip on the Pull Stud.
4. Z axis will move in a Positive Direction sufficient to clear the Spindle Tool and its Pull Stud (2nd Reference Return Position - G30).
5. The Carousal will retract to it's home position and index the new tool to the Tool Change Ready Position/
6. The Carousal will advance towards the Spindle to place the new toll under the Spindle.
7. The Z axis will move in a Negative Direction, back to the Z Reference Return Position (G28).
8. The Draw bar will grip the Pull Stud and pull the tool holder tight in the Spindle.
9. The Carousal will retract to its Home Position.
Try and describe the current action of the Tool Changer in term as above and advise at which step the process fails. If you do an actual test of the tool change process, do so without a tool to avoid a crash.
You really have to supply more and accurate information. Like, do you know if a Tool Change Macro is being used. This can normally be determined by viewing the parameters that are set to call a Macro Program via an M or a T code. However, if the battery that backs up the parameters died, the setting in these parameters will have been lost. If you have all the books that came with the machine, in the majority of cases, a copy of any tool change Macro will be included.
If the control uses a Tool Change Macro and you can list it here, it will be fairly simple to get you back on track.
Regards,
Bill
