Fanuc Oi-TD parameter manual
SeymourDumore
Aug 2, 2005
CT
Guys
Do any of you guys have a complete parameter manual for an Oi-TD control that you'd be willing to send me?
The one I've got with my machine is apparently missing a boatload of information.
There are parameters that the user manual is talking about, and yet there is nothing in the parameter manual.
Better yet, even in the parameter manual are references to certain parameters in the main text, yet not a single description of them anywhere.
For example, the backup procedure from the maintenance manual refers to Parameter 138, Bit 0, and yet, the parameter manual only describes Bit 7
Similarly, parameter 3191 is completely missing ( manual jumps from 3147 to 3193 ), and yet, the description of parameter 3107 Bit 3 refers to Par 3191 Bit 5.
This Fanuc CD is Version 3.6 if that means anything.
Thank You
AmericanMaker
Nov 23, 2020
Franklin, TN
I have these PDFs I can send you
Fanuc-B-64304EN-0/02 - 0i-MD Milling and Turning Operator Manual
Fanuc-B-64304EN-1/02 - 0i-MD Turning Operator Manual.pdf
Fanuc-B-64310EN-0/02 - 0i-MD Parameter Manual.pdf
SeymourDumore
Aug 2, 2005
CT
I have a PDF of manual B-64310EN/02. It has 3191 in it. PM an e-mail address if you want a copy.
Thank you to both of you guys!!!
With your help I've found the friggin' problem!
When opening the CD and clicking on the "PARAMETER" information, it opens up file: B-64304EN_04.
Well, that is the " OPERATOR'S MANUAL". It has programming and operation information in it, along with a stripped down selection of parameters.
After interrogating the CD, I have found the file you guys listed : B64310EN_04, which happens to be the complete parameter manual!
All looks to be well now, though there is a very good chance I will be asking some questions.
The machine came with a few idiosyncrasies, one of which is that in MDI mode neither the spindle override nor the feed override appears to be effective.
Anyway, I am in for a long digging-in evening!
Thank You Again!
