FANUC om control, Supermax Max1 "machine 0"
Andrewdini
May 2, 2019
hi, new to forum. also supermax max1 with fanuc om control. lost z-axis "machine" 0 and its shows about +34.627 above where it should be. would I adjust the 702 parameter lower? my machine was running fine before. lost zero return due to hand feeding too aggressively one time, now would go past machine 0(using zero return button). got stuck at top of z,pryed axis free, reset, then lost "machine" 0.
mine currently.
N0700 P 00000500
N0701 P 00000500
N0702 P 00000500
N0703 P 00000000
N0704 P-00600500
N0705 P-00400500
N0706 P-00460500
N0707 P 00000000
NO820 0
NO821 0
NO822 -00034627
or can i just change 822 to 0?
CG60
Mar 24, 2016
Andrew
Try zero return and then shutting off your machine and on start-up hold down P and Can (P cancel). Should return your position to zero. Had to do that a few times my self. May sure your are a slowest feed upon start-up.
G
Guest
Guest
Andrew
Agreed! The P cancel trick is the default go to in this situation.
kerseykyle
Jul 31, 2017
Washington state
I have a supermax max3, here is the values I have for the parameters you have.
N0700 P 00000500
N0701 P 00000500
N0702 P 00000500
N0703 P 00000000
N0704 P-01020500
N0705 P-00440500
N0706 P-00630500
N0707 P 00000000
N0820 P 00000000
N0821 P 00000000
N0822 P 00000000
Here is a page from one of the manuals documenting the parameter numbers you mentioned.
View attachment parameters.pdf
I have more user manuals if you want me to look something up.
Andrewdini
May 2, 2019
Thankyou for thew replies, did p-cancel tried to zero return again and yes fixed ty!!!!!!!!! damn that saved my ass big time lol im the only "machinist" in my shop so i would of been dead in the water lol. also i have the original manual in case anyone needs something looked up. :D
