bengineer08
- Jun 17, 2022
- Northern KY / Cincinnati area
Hello,
I've got a Fanuc Ot lathe I'm trouble shooting, a Miyano BND-34T. It has a third axis (B-axis, a turret parallel to the Z, but on center).
It was running great for a couple years. I use it intermittently, but was gearing up to start putting it through it's paces when I got an axis detect error out of the blue.
It was a 434 Servo alarm : 3 axis detect error. Nothing would power up, hydraulics don't kick on, can't jog motors.
I started with a lot to encoder cable and motor swapping back and forth (the X and B are the same motors, so I was swapping those & the cables back and forth). I got no change, so I assumed the cables and motors were good. I've replaced what feels like almost everything in the cabinet by now.
First I replaced the drive power board (something in the manual's trouble shooting somehow led me to believe it was not getting correct power). No change.
Second I replaced the servo amp board (it's a 3 in one board, so they all got replaced at once). This now gave me an X axis detect error instead of 3 axis (B axis), also the hydraulics would now power up, and I could jog the Z and B axes, when I try to jog the X it kicks out with the error. I swapped the old board back, and it went back to 3 axis detect error (and no hydraulics, no jogging). New board back in, X axis detect error (with hydraulics and Z & B jogging ok). I figured that's progress?
Third, I then replaced the Axis control board (think that's the nomenclature, the board where the encoder cables land in the cabinet). Again, no change, and swapping the old amp board back in still gives 3 axis detect error; new board back in gives X axis detect error.
The only thing I haven't swapped out are the cables and the motors. After swapping the cables, and the motors, and all combinations of cable/motors I can think of and not getting a change, I'm not so sure that will make a difference, but I'm not sure what else to try.
It feels like I'm getting a little progress by swapping the servo amp board, but I'm still stumped with the axis detect error jumping to a different axis (and it not changing when I swap the motors).
I'm buying these boards supposedly "tested" or "refurbished" off of ebay, but I figure if they didn't work, I wouldn't be getting these same errors. And with being able to jog the other axes with the new servo amp board, it seems like something outside of these boards?
To my limited knowledge there's nothing in this circuit aside from the cables and motors.
If anyone has any ideas on what to look at that I'm unaware of, I'd greatly appreciate the insight. Thanks.
