workhorsecnc
- Feb 19, 2022
- Dallas
Yep, already running into some of those problems. Good call. The orange extension cord is for the lighting inside the mill.Space looks nice. Get the light fixtures set up with LEDs. Maybe cost of $0.00. 20,000 sq ft of space cost me zip in 2020. There are free plans. Desk with laptop not only needs to be on castors, but also needs to be height adjustable. Oh, trash container is over full, and those wall mounted fans will blow all of the papers off your desk. Those papers will only land on spots where coolant has dripped. Never land on dry floor. And the orange extension cord is for too small to be running that mill.
Thanks for the advice.If you are going to have a client take a gamble on giving you production you need to make sure that machine is in good enough shape to no blow deadlines. Those are good machines but if something happens and you're down for a few weeks you could blow you shot at more work from that client. I had a spindle blow up on a 1.5 year old Okuma m560v covered under warranty and I just moved that production to one of the other 3 spindles close by for the 2 weeks it was down.
Make a riser for your chip bin and put a small air wand to knock the chips off. The down time of having swarf in the coolant tank always happens when you can't afford it.
I would also take a look at adding a few rolling carts for moving stock and finished parts around.
how is the rest of the space set up? Saw, tumbler, wash tub? There are certainly work around to all of those things but are nice to have.
Nice! We're in Arlington.What part of DFW are you in? I've got a small shop in Kaufman
That's a really good point. Thanks!"Finding Clients"....although my place was definitely built with "not what you know but who", whenever I was out, if I saw a business estate I'd drive around it and note the companies that looked interesting.
Then look them up on the interwebs for market sector, size, financials etc....
Try target OEM electronics companies with no machine shop.
If you go for machine shops and overspill, you'll only ever get work that they're already late with (so you'll have no time) and they'll drop you like a rock when they go light.
Also, they still want a margin, so you're working for cheaper parts....
