Total newbie, here; so please be patient with me.
I'm extending the threads on either end of tension rods that run under the steps (one each) of a library-type ladder. I built the ladder narrower than spec, so the rods need shortening, and, it turns out, longer threading on either end so that T-nuts can come in far enough to reach the outside of the rails of the ladder.
I found a metric die that seems to be the only one that fits the existing thread (M6 course thread), and I turned it for an additional quarter inch of threading on either end of a rod, backing it up every quarter turn to release the chip. All seemed to go well, and the T-nuts go on fine, but my new thread peaks aren't sharp like the existing threads; they look like they're squared off, looking fairly flattened and wide. Looking at the threaded rod end in profile, I can see that the originals are nice and pointy, while the new ones don't reach out as far and are, indeed, "flat-topped."
Any thoughts on what may be causing this? Seems odd that it's leaving the existing threads untouched, but lopping off tops of the new ones it's cutting.
Admittedly, I'm using an inexpensive Harbor Freight tap-and-die kit (I only have a very infrequent need; I actually bought it just for this project), but I gotta think it still should cut normal-looking threads. The only other thing I can think of is that I forgot to pick up cutting oil, so I was using WD-40, spraying it into the top of the die occasionally.
Thanks in advance for any wisdom.
