Krovvax
- Mar 5, 2012
- Quebec, Canada
So this week i was giving a try at Fusion 360 cam. We had a order of 64 piece to do so it was a good timing to try these HSM toolpath
here is a quick video of 1 of the roughing toolpath that i make
https://www.youtube.com/watch?v=Tf6_GcMeWdo&feature=youtu.be
I know the video quality is not the best but i film this with a tablet so sorry about that.
here is the spec of the cut
Material: SS 361L
size 4.750 long 1.5 width 0.500 height
Endmill: Niagara STR440 Stabilizer HT
5000 RPM
110 IPM
0.400 DOC
0.038 WOC
i know its not the most impressiv video out threre but i did this on a small tool room mill similar to a haas TM1 So here is the spec of the machine.
Mansford VM1000 Fagor 8055 I MC control
7.5 hp direct drive
454 IPM rapid travel
8000 RPM
Carrousel tool changer 10 position
around 8000 pounds
Here is a picture of the finish part
Finish part is 4.439x 1.280
the part also have 2 other feature (slot and circular) that i did with HSM strategie. both were using a 1/4 endmill at 7100 RPM 58 IPM 0.400 DOC 0.025 WOC. Both endmill (3/8 and 1/4) were doing the roughing/finishing of the piece (thanks to my 10 position carrousel) they also both of them do the whole 64 piece batch and were withing 0.001 from the first to the last piece so they hold up well.
I know its not the best toolpath or optimize program out there so every usefull information is the welcomre to get better in the futur.
I would also like to say thanks to zero_divide for the help he gave me with the speed/feed and after using is HSMadvisor i suggest to everyone to give it a try its realy worth it.
Sébastien
Material: SS 361L
5000 RPM
110 IPM
0.400 DOC
0.038 WOC
7.5 hp direct drive
8000 RPM
around 8000 pounds
Sébastien
