jwmelvin
- Sep 5, 2018
- northern Virginia
I recently bought a B&S Micromaster 618 and have just finished cleaning it and setting it up with new oil, metering valves, and a couple VFDs. It came with a Walker permanent magnetic chuck that was very difficult to actuate and had a ton of slop in the actuating mechanism. I disassembled the chuck, cleaned it up, and made new parts for the actuating mechanism. It's back together with a little RTV gasket in the joint between the aluminum body and top plate.
The machine table looks gruesome, with pitting (a few spots 0.005-0.009" deep) and staining, but measures very flat other than the pitting (by touching the unpitted spots or with parallels on the table).
Sitting on the table, the chuck is banana shaped—high on the ends 0.008" and pivoting about its center. I mapped the surface without any tension on the clamps and it is a fairly symmetric and single-axis curvature:
If I snug the clamps with 30 ft-lb, the chuck flattens out and measures pretty flat (~0.0005-0.001") from the far left side to about 2" from the right side, and from there rises about 0.002" to the far right side.
From what I understand, one might turn the chuck upside down, clean up its bottom, then flip it over to grind the top. If I do that, I'd be removing a bunch of material from the center of the bottom and then from the ends of the top. That seems undesirable, considering the amount of material I'd have to remove. On the other hand, using the table to flatten the chuck seems undesirable, considering the distortion it must induce in the table.
I have not put the chuck on the surface plate for any checks, but since the grinder table is flat when unloaded, and the chuck is flat when clamped, it seems like the chuck is mostly a uniform thickness, just curved. If the grinder table distorts from the clamp load, that would suggest the chuck is thinner at the edges. I was concerned that I did something weird when reassembling the chuck, like nonuniform RTV thickness, but I was pretty careful to put a thin uniform layer, and a little squeezed out all around.
I appreciate any advice you can give me.
