I used my freshly ground chuck to clean up the sides of a cheap cast-iron v-block. It came out with 0.0001” parallelism over the ~3x5” surface. I am happy, as it’s the first thing I’ve surface ground besides a block of steel and the chuck.
Nice.
You might pick up an eBay angle plate, perhaps 3 x 5"with 1/4 or 3/8* tapped holes and make a bar that can be bolted on to it, with one side of it having a long V so like a long V block. Make an number of diamond holders, one tall/long so to be clamped to yore V block and also be your slide diamond for dressing angles to your wheel.
dressing an angle you rough it in with your stone and then they your slide bar diamond on a parked wheel to know where it will contact the wheel (with it wheel-pushed tight to the angle plate, and so not far out long from your angle plat support.
Solid angle plates are more accurate the ones with holes because of the chance a hole may have a grit to fall on the chuck.
You can make/rough-in V blocks with a 45*dressed wheel and the V block resting on the chuck. Good to grind all your fixtures dead square so they can all be used for block-ins.
Oh, bolting on the bar add a C clamp as every set up needs two clamp methods to hold secure.
A slide bar diamond dresser makes quick accurate angle wheels, and wheel corner angles like a 45* for making quick part beveled edges. Make or buy a sine bar and make a home made JoBlock for 45* if you don't have a set of gauge blocks.
