Foam to make tool box organizers
SBAER
Aug 21, 2006
Kitchener, on canada
I want to make foam tray organizers for socket sets as well as other hand tools. I have seen the foam that I want used by other companies that make these organizers but I don't know what the foam is called. These other companies seem to have a way of milling this soft foam so that they can get pockets of varying depth. How do they do that? I was thinking of laser cutting an layering the foam to achieve blind pockets
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
When I want differing depths on the pockets, I just take the cutout piece and cut the thickness down to whatever I want in the bottom of the pocket and tuck it back in there.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Are you using a laser to cut out the shapes or just a knife?
I wish. MK1 pocketknife. Here is a sample drawer - though some of the tools are out. It's about due for an update though. Some of the screwdrivers are missing and I'm going to get a better screwdriver set. That means a new piece of foam. Going to use the space a little more efficiently too, so I can fit a few more items in there.
dcsipo
Oct 13, 2014
Baldwin, MD/USA
comes in many forms
Amazon.com : kaisen foam
eKretz
Diamond; Mod Squad
Mar 27, 2005
LOL Even the indicator remains has its place. What a guy!
Lol, that's just sitting there, not cut in. Almost looks like it in the photo though, heh. It's been left lying where it was dissected. Indicator is only good for parts now, shaft was bent somehow. Somebody probably dropped it. I picked up a box of about 10+ busted Teclock indicators with a toolbox I bought including contents some years ago. Every now and then I pull some parts off one to fix another.
technocrat
Feb 9, 2009
Oz
Multi-layer works well. Top layer is easy to cut all the way through for positioning, the bottom layer solid for cushioning. Glue if necessary when you are happy.
SBAER
Aug 21, 2006
I found some youtube videos of people routing the cross link polyethylene foam with a special cutter. Going to try gluing some of that foam on a thin layer of plywood and milling it in a VMC, Mcmaster Carr carries the special router bit.
Bill D
Apr 1, 2004
Modesto, CA USA
I wonder how pine or balsa wood would work? I will have to find some wood from a palm tree and see if it is usable for anything.
Bill D
Jeff_M_PA
Oct 31, 2008
San Diego, CA
Closed cell PE foam can be stuck together with a heat gun. You can buy sheets of two contrasting colors, which makes it easy to see what's missing. This is common in the aviation world where tool accounting is a huge safety factor. I used two sheets of 1/2". Not cheap. Here's a link with a video showing the process. I did it ages ago with a razor knife, which was a PITA. Laser cutter or waterjet would be a lot better. I think a CNC router would work well too. With a vacuum table, I don't see why a CNC will wouldn't work.
Jeff
dcsipo
Oct 13, 2014
Baldwin, MD/USA
Bill D
Be careful with wood choices, some may promote oxidation. Safe choices are things like Maple and Beech, commonly used for wooden planes. Mahagonny is used for storing tools, just make sure it is fully kiln dried. Avoid the varieties of oak. Pine may leak some pitch, Balsa is too soft to withstand extended use...a lot to consider.
moldcore
Dec 15, 2005
UTAH
Most of my measuring tools were purchased in the '70s and '80s. Some came in foam lined boxes or plastic containers. Regardless of the tool brand, almost all that foam has since disintegrated. Some rarely opened containers had the foam stuck to the tools that was very difficult to clean. I don't know what type of foam material was used back then, but obviously it was the wrong choice.
Chip Chester
Dec 13, 2007
Central Ohio USA
For us cheapskates out here (and we know who we are) has anyone tried those 2x2 foam tiles sold as either anti-fatigue mats or playroom mats (the multi-color ones). The ones I've seen have a slight grid on one side, and are smooth on the other. Seem easy to cut, but I have no idea of the corrosion characteristics of them...
