For Sale: South Bend 9 Follow Rest?
Chips Everywhere
Apr 29, 2021
Hello,
I bought what was sold as a Heavy 10 follow rest, turns out, its too small for a Heavy 10. My guess, it's for a South Bend 9in lathe. I paid 200 for it, asking 150 shipped or best offer.
Please PM if interested.
Will trade for Hardinge HC tooling.
jim rozen
Feb 26, 2004
peekskill, NY
Possibly not SB? If it were it would have a unit code on the main casting. If I had to guess I would suspect it's for a 9" seneca falls star lathe. My SF has a steady rest, with the same square-head adjusting screws.
Chips Everywhere
Apr 29, 2021
I'm pretty sure its for a SB lathe, I have a Heavy 10 follow rest and its identical to this one, just slightly bigger. A friend who has a SB 13" and 16" also has steady rest that look like this one. This is a parts diagram from South Bend
jim rozen
Feb 26, 2004
peekskill, NY
Look for the unit code stamped where they say it should be. For the record I was incorrect about the seneca falls guess, the separation between the mounting screws is much larger on that machine.
The separation between the mounting screws on my 10L is 1.25 inch, and the distance beween the centerline of the mounting screws, and the spindle centerline is 4.5 inch. Almost looks like that's what I see on your scale held up to the part.
mattthemuppet
Apr 22, 2016
San Antonio
If that fits my SB heavy 9 I'd be up for swapping the Buck chuck for it, if the chuck checks out and you're interested. The bolt holes on mine are 1 1/4" center to center and 4 1/8" center to spindle center.
Chips Everywhere
Apr 29, 2021
Not all tooling went out with codes, I have several South Bend tools and some attachments that do not have codes and where purchased N.O.S in their box. The casting has a 9W, but that is it.
I measured the follow rest.
Mounting holes center to center: 1.25"
Mounting hole center to follow rest "spindle center" is approximately 4.0-4.25"
jim rozen
Feb 26, 2004
peekskill, NY
Ooh. I have a rest like that for my heavy 9, I think. Will inspect that tonight and report back if it looks similar to the one you show.
Jim
mattthemuppet
Apr 22, 2016
San Antonio
I didn't know you had a heavy 9 Jim, that's good to know! The dimensions sound like a perfect fit for my heavy 9. Can't wait to pick up my chucks tomorrow :)
jim rozen
Feb 26, 2004
peekskill, NY
1) I don't have a follower rest for that H9 - but I do have what I think is an original steady rest, and there is no unit code number on it. Again the style of the fingers and the pusher screws, quite similar. Have not checked the dimensions on the mounting holes yet.
jim rozen
Feb 26, 2004
peekskill, NY
For that particular H9, the separation for the follower rest mounting holes is 1.25 inch, and the distance up to the spindle CL is 4.125 inch.
Chips Everywhere
Apr 29, 2021
Neat, I've never seen a Heavy 9. Looks almost like my Heavy 10, except I have a Cam Lock spindle and 2 tumbler gear box.
jim rozen
Feb 26, 2004
peekskill, NY
Yeah my big regret is the shop's not big enough to bring it into the basement. But it's warm and dry and fully functional. Keeps my motorbikes company.
I shortened the chip pan to make it look even more petite. BTW if the deal falls through (yeah right...) put me next in line please.
Chips Everywhere
Apr 29, 2021
I'll keep you posted.
mattthemuppet
Apr 22, 2016
San Antonio
posted pics to your HC chucker wanted threads. I think it's a beaut - if I hadn't gotten a PB adjust tru chuck in the same lot I'd be thinking really hard about keeping it :)
mattthemuppet
Apr 22, 2016
San Antonio
thanks to you Chips! I feel like I've found some rocking horse poo with hens teeth in it :)
chuck will go out Monday, I'll build a box for it once I finish my coffee.
mattthemuppet
Apr 22, 2016
San Antonio
looks pretty good to me :)
didn't spend a bunch of time fiddling with it as I had other stuff on my plate, but the bolts fit perfectly and the center height is spot on. I thought it was off center horizonally until I realised I could just move the cross slide :D It'll take a bit of practice to get use to..
Chips Everywhere
Apr 29, 2021
Nice, glad it worked out and that is going to be used.
