Good afternoon. I was wondering if any of you know the formula to be able to change rpms on a thread cycle on a lathe while maintaining start point. I have a thread that has started chattering really bad halfway and i want to change the rpm, but if I do, my threads won't line up. Is there a formula at all to be able to adjust the rpm to a number while keeping the same start?
Hello Hertz,
I've not tested this with a late model control, but certainly with a lathe equipped with a FS6T control, the index of the Thread was directly related the Spindle Revs and logically so, since the Threading pass is started based on the 1 Turn Signal output by the Spindle Encoder. Therefore, a Two Start Thread could be cut by either halving, or doubling the Spindle RPM used to cut the first lead, for use to cut the second lead.
Theoretically, if you wanted to re-cut a Thread that had just been cut with, say, 1800 RPM, if you were to halve the the Spindle RPM to 900, by shifting the Z Start Point by half the Thread Lead, the Threading Tool Should track in the same Thread Groove.
Also theoretically, you could extrapolate that out to use whatever the ratio of Spindle RPM change was, to the degree of Z Start Point change, to have the Threading Tool track in the same Thread Groove.
Regards,
Bill
