I have two strange issues with my newly acquired FP2. When I turn the dial to put the FP2 into high gear the pulley is tight and hard to turn via the rear aluminum wheel. It feels like what I would expect from low gear, but yet this is high gear. When I started it in this gear using my 3kw VFD I got some belt slip (albeit the belt was fairly loose). It seems to spool up slowly in high gear and slows quickly when power is removed. Low gear is much lighter and easier to turn and spools immediately albeit to its slower speed. Is there something I should be checking?
I have also noticed that my power feeds are not working as expected. The power feeds work fine with the rapids lever engaged (releasing has a distinct "notch" feel half way as the rapids lever swings back). Without the rapids lever engaged the leadscrew(s) turn a little and then stop when the feed is engaged. I have not removed the feed shear pin (to inspect) as I have to make a punch the correct size. The shear pin does however look intact. The feed shaft (where the shear pin is) spins until the feed level is engaged. Then turns a little and stops.
After 150hrs+ cleaning I was really hoping it would be smooth sailing when I powered it up..
Any ideas where I should start looking to troubleshoot these issues?
