I have for sale a nice 2013 DMC DT40I drill tap mill with a Sam Chully S200 4th axis, and a Fanuc oi-md control. The DMC has a 21 tool changer, uses bt30 toolholders. Machine has mostly cut brass. I bought 2 of these last year and the project I got them for didn't come through. I have power to it, but the batteries have gotten low and the machine has lost it's ref. points. I have gotten new batteries but have yet to install them, as I know nothing about Fanuc controls but will get it done before the machine ships. I have the x-y axis shipping bracket which I will install,will block the head,and load. Located in Albion IL. 62806. Looking for $17,000.loaded, or if you want to save money $16,000. you install new batteries and set the ref points. I also have a second one without the 4th axis I would sale for less or as a package deal. Any questions let me know. Thanks Jason
Specification Description
Table Size 27.6" x 15.7"
Travels X,Y,Z 23.6" x 15.7" x 13.8"
4th Axis Faceplate 7.9"
Spindle RPM 12,000 RPM
Table Capacity 551 lbs
Spindle HP 7.4/5.0 HP
Feed Rate 394 IPM
Tool Change Time (Tool to Tool) 1.3 Seconds
Tool Change Time (Chip to Chip) 2.0 Seconds
Rapid Traverse Rate (X&Y/Z) 1,890/1,417 IPM
Pull Stud Type P30T-1
Machine Dimensions 67" x 101" x 103"H
Machine Weight 5,776 lbs
Feed Rate 394 IPM
