BROTHERFRANK
- Dec 20, 2013
- SoCal
Hi all. This S700X1 Speedio is available for sale. This is a 16K rpm, Coolant Through Spindle (500 psi pump included), 21 Tool machine. X and Y travel is 700mm x 400mm (about 28" x 16") respectively. Floor Space is about 7' x 7'. Runs on 200-230 V 3 phase, 30 A . Comes with Blum Znano tool setter, larger 45 gallon coolant system with programmable chip wash, Coolant wash down hose, Auto-Lube (waylube), 100 MB memory, High Accuracy BII, MPG (set up handwheel), two LED work lights. The rotary is full 4th Yukiwa JNCH-170 High Speed with locking Yukiwa side support table. The Beere 6 cell 5C collet fixture is available as well. The machine was purchased new by the owner and is a 2014 with just over 3000 hours cycle time. Machined small parts with small (primarily 1/4" and under) cutters. They are asking $62k without the rotary set up, $69k with the rotary and side support. The Beere collet fixture they would let go for $3k (over $8000 new from Paws). The machine runs great. They have 5 Brother machines and just purchased a new M300X3 which will do the work the S700 was doing. Contact me for more info or post here.
