FS - Carbide endmills, 1/4" to 1", Square, Corner Rad, and Ball (with discounts!)
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Hi all,
New, quality carbide endmills, with discounts (for endmills 3/4" - 20mm and smaller) of 10% off over $100, and 20% and free USPS shipping for over $200. The 1" and 25mm cutters are damn cheap as-is, so aren't further discounted.
The pictures show the actual tools, but not always the full quantity. The text will have the make, size, flutes, coating (if applicable) and part numbers. Available pcs are listed, but I hope the formatting won't screw up when I bring it in from my working file. If it's bad, please PM me for a text file and larger pics to be emailed to you. Pics and text are synced, read down, then over and down again if you can't make out actual part numbers from the pictures.
There'll be two main posts in the thread, each with four pics and associated text. I'll post updates as cutters are sold, as I won't be able to edit the main posts past a day or so.
Kennametal 10mm x 22 x 71 2FL SE Carbide Ball End Mill 5682609 10 $21
Stellram 16mm x 32 x 116 4FL Carbide Ball End Mill TiAlN Heavy Core 5658821 3 $58
Kennametal 5/16 2FL Long Ball Nose Carbide End Mill 5058986 1 $29
Kennametal 5/8 x 3 x 6 2FL Carbide Ball End Mill 1257726 1 $68
Kennametal 16mm x 16 x 33 x 150 3FL TiAlN Carbide Ball End Mill 2417438 1 $54
Kennametal 1/2" x 1.5 x 6 2FL TiCN Carbide Ball End Mill 5059065 2 $64
Titan 1/2 x 3 x 6 4fl AlTiN .03CR Carbide End Mill TC24925 4 $65
Kennametal 3/4" x 1 x 3 2FL SE TiAlN Carbide Ball End Mill 2890995 2 $66
Kennametal 16mm x 30 x 88 4FL SE Carbide Ball End Mill 5654550 4 $35
Kennametal 3/8 x 1.5 x 6 2FL TiCN Carbide Ball End Mill 5059113 4 $42
Kennametal 1.00 x 3 x 6 2FL SE TiAlN Carbide Ball End Mill 2890999 7 $110
Kennametal 3/4" x 3 x 6 2FL SE TiN Carbide Ball End Mill 1115991 10 $88
Data Flute 1/2 x 5/8 x 2.5 3fl .030CR TiCN SSST30500C7 6 $22
Helical 1/2 x 2 x 5 5fl Aplus Coated HEV-L-50500 44307 4 $48
MA Ford 3/8 x 5/8 x 1.5 x 4 4fl .030CR AlTiMA coating 27747 2 $38
Benchmark 1/2 x 1.5 x 4 3fl ZrN 35050024C5 1 $44
Advanced Tool 1/2 x 1 x 3 3fl [none] 4 $24
Kennametal 3mm x 5 x 18 x 71 x 6 Shank 2FL .5CR Altin Coated Carbide EM 2657483 6 $19
IMCO 34262 3/4 x 1.63 x 4 2fl .060CR 34262 1 $65
IMCO 38078 3/4 x 1.63 x 4 2fl .125CR 38078 1 $65
IMCO 38077 3/4 x 1.63 x 4 2fl .090CR 38077 1 $65
IMCO 38514 3/4 x 1.63 x 4 2fl .156CR 38514 2 $65
Micro 100 1/2 x 1 x 4.5 x 6 5FL .030CR Carbide End Mill Weldon VLR-500-5-030 4 $82
SGS Z-Carb 7/16 x 1 x 2 x 6 4fl TiCN 36460 2 $40
Hanita 5/8 x 3/4 x 2.25 x 5 2fl End Mill 15080 2 $58
HTC USA-made 3/4 x 1.5 x 4 2fl End Mill 120-2750 2 $45
Hanita 3/4 x 1 x 3 3fl .030CR End Mill 15207 2 $50
Gorilla 3/4 x 1 x 4 5fl .030CR GMX-35 coating GM34RS5030 1 $76
Gorilla 3/4 x 1 x 4 5fl .060CR GMX-35 coating GM34RS5060 1 $76
IMCO 32943 1/4 x .38 x 2.5 2fl 45 deg 32943 12 $20
IMCO 39791 1/2 x 1 x 3 4fl AlTiN coating Weldon 39791 5 $33
IMCO 34424 3/8 x 1 x 2.5 4fl TiCN coating 34424 3 $24
IMCO 34624 3/8 x 1 x 2.5 2fl TiCN coating 34624 6 $24
IMCO 98244 3/8 x 1 x 2.5 4fl AlTiN coating 98244 1 $24
Milland
Jul 6, 2006
Endmills for sale, part 2
IMCO 65260 1/2 x 1 x 3 5fl .030CR AlCrNX coating 65260 2 $36
IMCO 67223 1/2 x 1.25 x 3 4fl .015CR AlCrNX coating 67223 2 $36
IMCO 67224 1/2 x 1.25 x 3 4fl .030CR AlCrNX coating 67224 3 $36
IMCO 67225 1/2 x 1.25 x 3 4fl .060CR AlCrNX coating 67225 2 $36
IMCO 67233 1/2 x 1.63 x 4 4fl .030CR AlCrNX coating 67233 1 $58
IMCO 38125 1/2 x .63 x 3.38 x 6 3fl .125CR 38125 1 $68
Kyocera 1/4 x 3/8 x 1.5 x 4 3fl .010CR 1744-2500.1250C 2 $26
Kyocera 1/4 x 3/8 x 3.25 x 6 3fl .030CR 1744-2500.3000C 1 $36
IMCO 65213 1/2 x .63 x 2.5 5fl AlCrNX coating 65213 1 $33
IMCO 65215 1/2 x .63 x 2.5 5fl .060CR AlCrNX coating 65215 1 $35
IMCO 65253 1/2 x 1 x 3 5fl AlCrNX coating 65253 1 $36
IMCO 65267 1/2 x 1.25 x 3 5fl AlCrNX coating 65267 1 $36
IMCO 65269 1/2 x 1.25 x 3 5fl .030CR AlCrNX coating 65269 1 $36
IMCO 67132 3/8 x 1.25 x 3 4fl AlCrNX coating 67132 1 $28
Kennametal 1.00 x 1.25 x 3.25 x 6 4FL SE Harvi Safelock .120 CR Carb AlTiN 5360391 1 $110
Kennametal 25mm x 25 x 75 x 150 6FL SE CR High Perf Ruf Carb EM AlTiN 1807169 2 $110
Kennametal 1.00 x 1.38 x 4 2FL SE .120 CR Carbide End Mill 3876646 1 $90
Widia 4K2316076 5/8 x 3 x 5.25 3fl Carbide End Mill 4K2316076 3 $60
Kennametal 20mm x 22 x 92 .25CH 3FL SE TiAlN Coated Carbide End Mill 1996489 2 $63
Kennametal 12mm x 12 x 36 x 65 2fl reduced shank heavy core 5667667 2 $32
Kennametal 7/16 x 2 x 4 2FL SE TiCN Coated Carbide End Mill 5056517 1 $34
Stellram 152 Series 20mm x 18 x 80 x 120 reduced shank heavy core 5659873 12 $84
Micro 100 5/8 x 1.25 x 4.5 x 6 2fl TiCN High Performance reduced shank GLR-625-2X 5 $94
Kennametal 5/8 x 1.25 x 3.5 .02 CHAM AlTin Variable helix 4067256 6 $63
Kennametal 1.00 x 1.63 x 4 2FL SE .120 CR Carbide End Mill Uncoated 3658932 10 $95
Kennametal 1.00 x 2.75 x 6 2FL SE .060CR Carbide End Mill 3876657 2 $105
Kennametal 1.00 x 2.25 x 5 2FL SE 0.090 CR Carbide End Mill, 3876652 5 $100
Kennametal 1.00 x 2.25 x 5 2FL SE .060CR Carbide End Mill 3658935 3 $100
Kennametal 1.00 x 2 x 5 2FL SE Carbide End Mill, 0.090 CR 3876650 3 $100
Kennametal 25mm x 38 x 75 x 135 4FL Roughing Carbide EM, 4mm CR TiALN 2406184 5 $105
Kennametal Stellram 1.00 x 2 x 5 4FL SE .156 CR, Altin Carbide End Mill 5652483 3 $105
Kennametal 25mm x 38 x 75 x 135 4FL Roughing Carbide EM, 3mm CR TiALN 2429691 5 $105
Kennametal 1.00 x 3 x 6 2FL SE Carbide End Mill, 0.030 CR 3876654 11 $105
Kennametal 3/4 x 1 x 3 2FL SE Carbide End Mill, TiN 1115596 8 $45
Stellram 5/8" x 1.25 x 3.5 4FL 0.120 CR, Altin Coated Carbide End Mill 5653640 7 $52
Advanced Tool 9/16 x 2 x 6 2fl AlTiN 11370-200 7 $60
Kennametal 5/8 x 2.25 x 5 2FL SE 0.060CR Carbide End Mill 3658918 9 $64
Kennametal 5/8 x 1.25 x 3.5 6fl .03 CR AlTin Variable flute spacing for Ti 5351829 4 $63
Kennametal 16mm x 32 x 90 6fl 0.5mm CR AlTin Variable flute spacing for Ti 5682097 7 $63
Kennametal 1/2 x 2.5 x 5 2FL Carbide End Mill TiCN coated 3900307 4 $45
Kennametal 12mm x 19 x 65 x 112 2FL SE 1mmCR HP Carbide End Mill 2657493 6 $33 (toroidal type)
Kennametal 3/8 x 1.5 x 4 5FL SE High Helix Carbide End Mill 5057436 10 $38
Kennametal 12mm x 50 x 100 4FL SE Carbide End Mill 1192169 10 $34
Kennametal 7/16" 2 x 4.5 4FL SE TiALN Coated Carbide End Mill 5682512 10 $32
Kennametal 20mm x 38 x 100 2FL SE Carbide End Mill 5667891 4 $48
cpifer3
Dec 24, 2012
OHIO
Ill try the
Ill take all 3
Thanks
M. Moore
Jun 8, 2007
Vancouver Island, B.C. Canada
Milland,
I would like a few of your end mills as follows.
#18, Advanced tool, 4 @ 1/2" x 1" x 3" x 3fl,
#27, HTC, 2@ 3/4" x 1.5" x 4"x 2fl,
#31, Imco, 3@ 1/4" x .38" x 2.5" x 2fl, 32943,
#34, Imco, 2@ 3/8" x 1" x 2.5" 2fl, 34624
#56 Kennemetal, 1 @ 7/16 2 fl, 5056517,
I think that is a total of $328.00 before discount and shipping.
I am hoping you will ship USPS to Canada? I understand it may cost a bit extra.
I am happy to pay with Paypal.
Thanks,
Michael
Milland
Jul 6, 2006
Milland,
Thanks,
Michael
Hi Michael, yes, it's $328, with the discount it's $262.40 USD. There will be some extra due to paperwork for Canadian shipping, please PM or email (better, in the same contact field) your full address to me so I can get the costs together. Thanks!
Randalthor
Mar 7, 2018
Kansas City
I come up with $188.80 after discount. Please PM me with your email and I'll Paypal you back. Thanks.
cpifer3
Dec 24, 2012
OHIO
Got my mills yesterday, look great, never used imco before, look forward to trying them. Thanks
Milland
Jul 6, 2006
Emailed you, and I do have all these endmills available. I may have to update the list to reflect those tools that have sold.
Milland
Jul 6, 2006
Updated list, new discounts (for Monday 2/25 and Tuesday 2/26 only!)
Hi all,
Here's the list of endmills will items sold marked as such, and remaining quantities corrected. However, new discounts for today (2/25) and tomorrow (2/26) are in place, but only for endmills bought and paid for these two days, then these cutters will go to ebay.
From this list, purchases over $100 are 20% off, over $200 are 30% off plus free shipping - that's a discount increase of 10% for each. Also, large cutters (25mm and 1") are now discounted 20% when buying at least two pieces, including from this thread:
https://www.practicalmachinist.com/...lls-sale-cheap-359828/index2.html#post3311968
Pictures remain as in posts 1 &2. Thanks for checking these out!
Ball
Kennametal 1/2" x 1.5 x 6 2FL TiCN Carbide Ball End Mill 5059065 SOLD $64
Endmills 1
Advanced Tool 1/2 x 1 x 3 3fl [none] SOLD $24
Endmills 2
Micro 100 1/2 x 1 x 4.5 x 6 5FL .030CR Carbide End Mill Weldon VLR-500-5-030 3 $82
Hanita 5/8 x 3/4 x 2.25 x 5 2fl End Mill 15080 SOLD $58
HTC USA-made 3/4 x 1.5 x 4 2fl End Mill 120-2750 SOLD $45
Gorilla 3/4 x 1 x 4 5fl .030CR GMX-35 coating GM34RS5030 SOLD $76
Endmills 3
IMCO 32943 1/4 x .38 x 2.5 2fl 45 deg 32943 9 $20
IMCO 34624 3/8 x 1 x 2.5 2fl TiCN coating 34624 4 $24
IMCO 98244 3/8 x 1 x 2.5 4fl AlTiN coating 98244 SOLD $24
Endmills 4
IMCO 67223 1/2 x 1.25 x 3 4fl .015CR AlCrNX coating 67223 SOLD $36
IMCO 67224 1/2 x 1.25 x 3 4fl .030CR AlCrNX coating 67224 SOLD $36
IMCO 65267 1/2 x 1.25 x 3 5fl AlCrNX coating 65267 SOLD $36
IMCO 67132 3/8 x 1.25 x 3 4fl AlCrNX coating 67132 SOLD $28
Endmills 5
Kennametal 7/16 x 2 x 4 2FL SE TiCN Coated Carbide End Mill 5056517 SOLD $34
Endmills 6
Endmills 7
Advanced Tool 9/16 x 2 x 6 2fl AlTiN 11370-200 6 $60
