1. 2001 Linde E20P...4000 lb capacity, IMHO, the ultimate electric forklift...4 wheels and *pneumatic* tires...and will turn in as tight an radius as a 3 wheel lift. 3 stage mast, 42 inch forks but 54 inch ones available. 48 volts. Has side shift capabilty but no side shift carriage on it presently. Typical dealer price on these is $8,000 to $16,000 (see www.eliftruck.com for examples), brand new tires (but not installed yet), battery is good, price on this one $6,500.
Btw, this thing will run outside without getting stuck where some LP pneumatics get stuck. The reason is most LP trucks are like a car...one wheel slips and the other wheel does nothing. On the Linde E20P, both drive wheels are independantly powered !
2. Daewoo BC25S... 5,000 lb electric, 3 stage mast, 4 valves (for side shift and fork positioning possiblities). Not sure of year...probably 1998 or so. Runs great but has no side shift carriage or forks. Battery iffy...ironically the battery looks like new but has sulfate on plates due to dealer not keeping it charged for years on the pallet before it was sold. Currently 48 volts but can be changed to 36 volts. FWIW, with this comes a complete decal and nameplate kit....I had the idea to complete restore this one to like new appearance but never got around to it...even have new aluminum nameplate with all data filled in.... $2,600
3. Long Reach paper roll attachment for Class 2. Appears to be NOS...perfect. Will grip and rotate under hydraulic control 360 degrees. Common as dirt in large Class 3 units, but very rare in Class 2 small size like this. I presume it could be used to pick up and rotate 55 gallon drums as well. Quick change hydraulic fittings. $2,500
4. Cascade slip sheet push/pull attachment, Class 2. Appears almost new. QC hydraulic fittings. $1,750
5. Cascade F55 side shift/fork positioner attachments, Class 2 Have 3 of them...all brand new, never used. The "catch" is they are wider than normal.. 49 inches wide...which is a good thing for outside lifts where extra fork spreads are a plus sometimes...but a bad thing for inside lifts where the extra width might get in the way in tight situations. (they are wider than a typical inside 4,000 lb lift by about 4 inches each side)
$1,850 each
6. Grove inside crane style manlift. Year 2000. Has the advantage over JLG type scissor lifts in that it can reach over machines or whatever to get to lights and such in tall buildings. Batteries were good last I checked two years ago, but need to recheck $3,850. Batteries are four deep cycle 6 volt batteries per side (i.e. 8 batteries total)
7. Bonzoni Class 3 side shift... new, never used $1,200
8. Baker 4,000 lb electric forklift. 2 stage mast, side shift. 1988 or so. Works fine but battery shot. (works enough to demo that all works ok but has a bad cell) No forks, but uses cheap and common class 2 forks. 36 volts. Clean unit, great tires. $1,250
9. Linde complete mast assembly, hoses and all...brand new, never used ! Class 2, three stage. Appears to be for a 4 to 5,000 lb cap. lift Would make for a fantastic "turn your truck or tractor into a forklift" conversion. $1,850.
10. Linde library...bookcase full of Linde shop manuals, parts books, etc $250
And yes, I know I need some pictures...here's a few...probaby not in order, but you can figure it out...
www.practicalmachinist.com/linde61.jpg
www.practicalmachinist.com/linde34.jpg
www.practicalmachinist.com/linde31.jpg
www.practicalmachinist.com/linde35.jpg
www.practicalmachinist.com/linde33.jpg
www.practicalmachinist.com/linde60.jpg
www.practicalmachinist.com/daewoo40.jpg
Re the Grove manlift...not mine, but here's a sistership... same model.. www.scissorlifts.ca/images/groveamz39e-manlift.jpg
And here's a sistership to the Baker forklift http://cdn3.iofferphoto.com/img/item/123/506/483/I8ts.jpg Mine looks a little nicer though.
[email protected]
$1,850 each
[email protected]
