Eric U
- Feb 26, 2003
- Eastern AL
Currently asking $22,700
LOW HOURS!
Specifications:
Control: Haas
X-Axis Travels: 8"
Z-Axis Travel: 30"
Swing Over Front Apron: 16"
Swing Over Cross Slide: 9.5"
Chuck Size: 8"
Max Cutting Diameter: 16"
Max Cutting Length: 30"
Distance Between Centers: 30"
Max Spindle Speed: 2,000 RPM
Spindle Motor: 7.5 HP
Spindle Nose: A2-5
Spindle Bore: 2.31"
Rapid Traverse Rates: 200 IPM
Machine Weight: 4,400 Lbs.
Machine Dimensions: 83.2"L x 54.4"W x 78"H
Electric: 220V Single or Three-Phase
Equipped With:
Manual 3 Jaw BTC Set-Tru Chuck (with Chuck Key)
Coolant Pump Kit
Manual Tailstock with Skoda Live Center
Dorian CXA Toolpost (with Wrench for Top Nut)
4 Aloris Toolholders (2x CXA-1, 1x CXA-2, 1x CXA-4)
Halogen Work Light
Front Table
Tool Bin
Grease Gun
Rigid Tapping
15" Color LCD Display
USB
Intuitive Programming
Visual Quick Code
Manual
630 hours power on
178 hours spindle on
147 hours cutting feed
I am the original owner of this lathe. It was purchased new in 2008. In the time I've owned it, it has always been used and stored in climate controlled shops. This lathe was used 95% for cutting aluminum (my own products). The other 5% was for gunsmithing and installing rifle barrels.
I made three modifications to this lathe: first was to install the pieces of channel to the front of the lathe to help redirect coolant back to the coolant tank (easily removed if desired). Second was to install the halogen work light to the backsplash, which is plugged into an existing accessory outlet. And third, was to install an outboard spider to the spindle for use in chambering and crowning rifle barrels for gunsmithing. The original Haas spindle end cap is included if this last option is not desired.
I will skid and load the lathe onto your flatbed trailer. I have a forklift, but I don't know if it will pick up this lathe. If it will not, I will rent one to load the lathe onto your trailer.
See video tour of the lathe here (turn up volume to hear my commentary and to listen to spindle):
Haas TL 1 Video - YouTube
Copy and paste if link doesn't show in this listing.
Lathe can be seen under power at my location with prior arrangement.
Reason for selling is I have a new Doosan Lynx turning center more appropriate for production parts.
Contact me at: [email protected]
Purchase Information:
This item is listed elsewhere. Please verify its availability!
Specifications and features are subject to buyer verification
Cleared funds are required prior to pickup
Payment methods include wire transfer, certified check, company check, or cash.
Machine will be skidded for loading onto your flatbed trailer
Subject to prior sale.
The lathe and accessories are sold "AS - IS, Where - IS" and with all faults. Items are described to the best of our knowledge. We make no guarantees regarding accuracy, errors or omissions in item descriptions and make no warranty, express or implied as to the nature, quality, value or condition of any item. We expressly disclaim any warranty of merchantability or fitness for a particular purpose of any item.
LOW HOURS!
Specifications:
Control: Haas
X-Axis Travels: 8"
Z-Axis Travel: 30"
Chuck Size: 8"
Spindle Nose: A2-5
Spindle Bore: 2.31"
Equipped With:
Coolant Pump Kit
Halogen Work Light
Front Table
Tool Bin
Grease Gun
Rigid Tapping
USB
Visual Quick Code
Manual
630 hours power on
