itsmeBernie
- Jul 2, 2005
- Northern New Jersey
Electro Mechano High Speed Precision Drill Press Model 105W
Asking $550
Fantastic working condition. In really clean, original shape.
Speed control great at maintaining drill speed
I am ONLY selling it because I am still keeping one just like it!! I love this drill press.
EASILY mounted onto other machines like a milling machine if necessary. EM makes an adapter, but one can be easily custom made for your application due to its design.
A really nicely appointed, easy to operate, flexible capacity, easily modular, micro-drill.
Factory Upgraded with:
-JACOBS #0 DRILL CHUCK & WRENCH (0-5/32” CAPACITY)
-DRILL COUNTERBALANCE
To increase sensitivity in drill feed, a frictionless counterbalance is available in place of the standard return spring.
COUNTER WEIGHT PROVIDES FINE FEEL FOR THE SMALLEST DRILL BIT
-EXTENSION ARMS and HEAVY CAST IRON PRODUCTION BASE
Increases throat depth to 8". permitting
drilling to the center of a 16" workpiece
Spindle square to base & table at 2-1/2"(83) radius ........... .003"
Spindle square to precision table at 2-1/2"(83) radius ........ .001"
Reply mentioning this listing in YOUR message for quickest reply so I can avoid BOTS.
I will try to be good to check messages here, but email direct if you like:
itsme_bernie AT yahoo DOT com
Thanks
Bernie
Electro Mechano High Speed Precision Drill Press Model 105W - tools...
Factory Info:
Model 105W
“Heavy Duty” line of Micro Drill Presses
DRILLS .004" to 5/32"
Spindle Speed . . . . . . 2,500-15,000 RPM
Motor . . . . . . . . . . . . . . . . . . . . . 1/8 HP. @ 6,000 RPM
Motor operates on 110 to 125 volts AC or DC 25 to 60 cycles
Spindle Stroke . . . . . . . . . . . . . . . . . . . . . 1-1/2"
Chuck Run-Out . . . . . . . . . . . . . . . . Max. .001"
Spindle Feed . . . . . . . . . . . . . . . . . . . . . Micro & Direct
Base Working Surface . . . . . . . . . . . 14” x 16”
Weight . . . . . . . . . Net 38 lbs. (17.25 kg) — 52 lbs. (24 kg)
**More like 60lbs with the larger baseplate.
Here is some information taken from Electro Mechano's web site:
1. Sturdy Mounting - Side play, one of the main causes of drill breakage and poorly drilled holes, has been eliminated through the use of wide spaced, extra long quill bushings secured in rugged yoke.
2. Quick Set Speed Control - Front mounted lever indicating actual drill RPM permits quick adjustment of spindle speed. No need to remove covers, loosen belts or change belt positions. Continuously variable speeds from 1000 to 10,000 rpm or 2500 to 15,000 rpm. For speeds from 15,000 to 25,000 rpm, an SCR controller is added. The addition of the solid state controller eliminates the governor.
3. Centrifugal Governor - Unlike conventional rheostatic speed control which permits speed variances with load changes, Electro-Mechano's centrifugal governor maintains exact desired drill speed, load or no load. This means greater accuracy, faster production and less drill breakage.
4. Perfect Balance - Armature, governor and chuck mounted on a single shaft results in minimum vibration and smooth chuck operation at all speeds.
5. Dependable High-Speed Motor - Electro-Mechano's compact, universal-type motor is engineered to supply adequate power for drilling all types of material. Delivers trouble-free, dependable long-life performance for thousands of hours of continuous production drilling.
6. Positive Depth Stop - Easily adjustable mechanical depth stop insures close depth tolerances. Mounted close to the quill, the depth stop exerts no lateral pressure on drill.
7. Micro-Feel Control - Provides 4:1 reduction ratio for sensitive feed for drills down to .004". Micro-feed is standard on Models 101 and 105. Direct feed is used for No.60 to 5/32" drills. Either feed is instantly available by a simple engagement mechanism. This dual feed feature insures precise control for every drill size.
Asking $550
Thanks
Bernie
Factory Info:
Model 105W
