FS: Jacobs drill chucks, LIke new Kant-Twist clamps, a few collets and 244 pictures of thing you can own.
lazz
Feb 12, 2012
The warm desert of Phoenix Arizona
As usual I dont care about payment.... Mail me a check.... paypal ...what ever you wanna do works for me.
First dibs are awarded to the first post. Send a follow up PM and tell me how you wanna pay and Ill get you the necessary details.
Shipping.... Everything will be plus shipping....Im sending this via USPS flat rate boxes.... The cheapest rate possible....
First Revised list
#1
B1,2)<<<SOLD>>>Jacobs #36 MT4 3/16"-3/4" with key, works could use more cleaning $45 each
B3)<<<SOLD>>> Jacobs #36 1" shank with key, works could use more cleaning $45 each
C1,2) Jacobs #36B threaded 3/4"x 16 with key, .18 - .80 $40 each
D1,2) Jacobe 6A #2MT with key, 0-1/2" works could use more cleaning $25 each
E) Jacobs 2A with key, 3/4" shank 0-3/8" $15
F) Jacobs 32 with key 3/4" shank 0-3/8" $15
G)<<<SOLD>>> Jacobs #0 0-5/32 with key , 1/2 shank $10
H) Jacobs 31Ba 3/8x24 threaded. $5 maybe new under the wax. Maybe not.
Near new Kant twist clamps.
<<<SOLD>>>12" 1 pair $175
<<<SOLD>>>6D, 421 1 pair $70
<<<SOLD>>>420 2 pair $65 per pair.
<<<SOLD>>> 4 1/2", 415 2 pair $50 per pair
<<<SOLD>>>3", 410 2 pair $45 per pair
<<<SOLD>>>2 1/2" D 2 pair $25 per pair
<<<SOLD>>> 2", 405 2 pair $25 per pair
<<<SOLD>> 1", 401 2 pair $18 per pair
<<<SOLD>>>1", 401 USED 2 pair $15 per pair
#2
A) 3 @ 5/8" and 2 @ 5/16"? the 2 uncoated ones have chips other wise sharpe $10 for all of them
B)1- 2x3 $10 for the pair
C)<<<SOLD>>> 4 coated shell mills $20 for all
D)<<<SOLD>>> 6 sharpe ? uncoated shell mills, only 5 in the picture all 6 for $15
E) 3 arbors with cutters. the one with the letter E is welded. $15 for all of them
F) Valentine vsc-4125-6b125 With a 1" Weldon arbor $25
G) 16TPI thread comb $10
H) When I first saw this it was coated with wax. It looked like an R8 shank. My first thought was what Bridgeport could possibly turn this?
Futuremill wedge 60707-2 $30
K) Valentine ba-3.5-4r on a 40 taper $25
L) Royel tap holder 1" shank $15
M) 4 pieces 0-1/2 drill chuck, 1", 3/4, and 1/2" unknown mount. $25 for all 4
N) Taper 40 kwik-switch 300 master 804446,80351,80348, 80339 near new $150 for all
O) 1" arbor shank small end is 1" , large end 1.80" over 2.7" $10
#3
A) 2 Morse form tools new? $ 20 for the pair
B) Kennametal Kenlock LSR-5 $15
C) Enco missing one clamp $5
D) Valentine $10
E) 1" shank $8
F) Kennametal 3/4" shank $15
G) Valentine 1" shank $15
H) 2 3/4" dia 1" shank extra inserts? $15
L) 1 1/4" dia 4 1/4 long 10 inserts $25 (If this doesnt sell thats okay)
M) Kopal two model 2-42, two model 2-18 chamfer tools with 4 large and 2 small extra blades $135 for all.
N) Darex cbn 2115 Are they junk or can y9u use them $15 for the pair
O)<<<SOLD>>> Fly cutters 2 1/2" dia 3/4" shank, 2" dia 3/4" shank , 1 1/2" dia 1/2" shank $15 for the 3
P) <<<SOLD>>>Manchester m-25 2 1/2" dia 1/2" shank, extra inserts. $15
#4
A) Misc hold down studs 4" - 8" and nuts. 5/16" - 3/8" wax too $15 for all
B) 3"-8" 1/2" stund with wax $10
C) 1" X 2" X 3 1/2"@ 6pair and 3 singles $5 per pair $3 for the 3 mismatched
D) 1 1/2" x 2 1/4" x 3 7/8" 2 pair $7 per pair
E) 1/1/2" x 3 3/8" x 5 5/8" 2 pair & 3 chiped. $10 per pair $8 for the 3 chipped
F) 1 1/2" x 1 1/2" x 2 3/8" 2 pair & 3 chiped. $7 per pair $7 for the 3 chiped
G) $10 for 13
H) <<<SOLD>>>5/8" 3" -8" 8 misc straps, 5 flange nuts, 20 studs, 12 tnuts $25 for all
K)<<<SOLD>>> 1/2" 11 straps, 5 flange nuts, 11 tnuts $10
L) <<<SOLD>>>1/2" 20+studs 3"-8" some with wax $10
M)<<<SOLD>>> 1/2" 20+studs 4"-8" some with wax $10
The second page of goodies.
#5
A) Brown & Sharpe 788-360 without the collet clamp, two 1/4X 20 threaded holes 2 1/2" cubes $12 each
B) 5 pair 1" x 2" x 3" threaded holes $12 per pair
C) Dorian 73310102500 new $80
D) Fette F001 like new, 4X40 dies and misc $675
E<<<SOLD>>>) 6" height gage $75
F)<<<SOLD>>> New poorly stored SPI swiss made 98-430-2 a few have surface rust. $45
G) Brown & Sharpe 11-236-332 $25
H)<<<SOLD>>> This is a hard one... If it does not sell room will be made on the " have you ever seen one of these" shelf
New unused 2 1/2" Mini-Sine. notice the 1965 price. $75
K) <<<SOLD>>>Red or Black your choice $3
L)<<<SOLD>>> 1/4" 7 or 8 pair $15
M)<<<SOLD>>> 1/8" & 1/4" 6 pair and 6 singles $10
N)<<<SPOKEN FOR>>> Toe clamps $75
O)<<<SPOKEN FOR>>> Hefco stack blocks 1.52" X 3.03" x 2.21" $20 for the pair
Q) <<<SPOKEN FOR>>>Single 1.38" x 1.96" x 2.34" $10
R) new unused Vertex 5" X .30... 1.38" center to center holes 1.10" center
21, 23, 27, 29, 31, 33
37, 39, 41, 43, 47, 49 $25 for the pair
S) They can be anything you want them to be $5 for the pair.
#6
A)<<<SOLD>>> Dumore 16-11 with a custom 1" base and a variable speed. Dissembled this could fit in a Large flat rate box $250
B) Tool Post Grinder Dumore 2Ag with the movable base . Both internal and external. $240
C) Tool Post Grinder Southbend ?? Keith Rucker just made a spindle for its brother. Local pickup might be necessary $250
D) Dumore D2 needs a cord and base runs That 1/8" spindle almost went to a different project $50
E) 1/8 spindle runs, A new cord might be a good idea $35
F) Mighty Mini oil skimmer and fittings. Runs $225
G) Tool Post Grinder For a smaller lathe maybe a 9c or the not to be mentioned 47!4$ Runs with a cord hooked up. Needs a belt and cord... $50
#7
A) 25+ counter bores $30
B) 29/32" with thru oil hole #3MT $ 15 for the pair
C) <<<SOLD>>>7/8", 1", 1 1/8", 1/1/4", 1 3/8", 1 1/2" the 1" is USA 1/2" and 3/4" shank $15
D) <<<SOLD>>>2 1/2" Rutland MT#4 $15
E) <<<SOLD>>>15/16" MT#3 or 1 3/8" MT#4 $10 each
F) <<<SOLD>>>1/2" X 12" MT#2 New? $15
G) (1) 1 1/4", (3) 1 5/32" altered shanks $10 for all 5
H) <<<SOLD>>>50 + reamers $40
K)<<<SOLD>>> 60+ taps $45
#8
A)<<<SOLD>>> Hardinge H-4 This fixture has seen some action. But its tough and ready for me. $175
B&C) Objects that appear to be 5C collet fixtures. I didnt do well with them Your choice $7.50
D) Phase II It could use a cleaning $25
E) Better makers 5C Collets $5 each
Royal 1/8", Rivet 3/32", 7/32", 15/16" Buck 1/2"
Hardinge 3/16", 3@ 5/16", 13/16"
F) China, Taiwan 5C collets $3 each
1/16" X2 5/16" X4 21/32"
7/64" 3/8" X3
1/8" X4 1/2" X2 3/4"
5/32" 13/16" X2
3/16" X2 9/16" 31/32" X2
1/4" X3 19/32" 7/8"
9/32" 5/8" X2 15/16"
1 1/16" 1 1/8"
G) 5 shop made collets that appear to be brass and steel 3c $20
H) Universal Engineering 90397 & 2 AcuraFlex collets $17
K) Near new Sandvik s8-6-c3nf and 3 3/16" collets $20
L) 20+ taping collets $30 for all of them. The wood block might be expensive to ship whole...
M)26 200DA collets $60
N) 1/4", 5/16", 2@3/8", 7/16",3@1/2", 5/8", 11/16", 7/8" 2.03 tall 1.37 dia $20
O) EA 6802K 1/4", 3@5/16", 3/8", 2 7/16", 1/8P $15 for all
p) AF11 collets [email protected], 3@2MM, 2.5MM, 6.5MM, 2@ 3/16", 1/4", 13/64" $20
S1) MHC 4" X 1 1/8" 09743402 $45
S2) SPI 3" X1" 71-473-3 $40
S3,4,5,6) MHC 6" X 1 1/8" 09743600 $85 each
S7,8) MHC 5" X 1 3/16 09743501 $70 each
PM to follow.
I’ll take:
D 2.5” mt#4 drill
E 15/16” drill and 1 3/8” drill
D four shell mills
E six shell mills
I’ll take the following:
B1,2) Jacobs #36 MT4 3/16"-3/4" with key, works could use more cleaning $45 each
B3) Jacobs #36 1" shank with key, works could use more cleaning $45 each
Qty 2 of #5 A) Brown & Sharpe 788-360 without the collet clamp, two 1/4X 20 threaded holes 2 1/2" cubes $12 each
A) Hardinge H-4 This fixture has seen some action. But its tough and ready for me. $175
Pm incoming.
I would like:
K) 1/2" 11 straps, 5 flange nuts, 11 tnuts $10
L) 1/2" 20+studs 3"-8" some with wax $10
M) 1/2" 20+studs 4"-8" some with wax $10
From second page:
E) 6" height gage $75
F) New poorly stored SPI swiss made 98-430-2 a few have surface rust. $45
K) Red or Black your choice $3 --I would do both unless someone else really needs one
L) 1/4" 7 or 8 pair $15
M) 1/8" & 1/4" 6 pair and 6 singles $10
F) China, Taiwan 5C collets $3 each --I would like the 1" size
edit to add from group #4:
H) 5/8" 3" -8" 8 misc straps, 5 flange nuts, 20 studs, 12 tnuts $25 for all ---if not spoken for already
I’ll take B1 and B2 and B3 (the Jacob’s #36 drill chucks), qty 2 of 5a (the B&S blocks), and 8a, the hardinge 5c fixture. Pm incoming.
I sent a PM on B1 _or_ B2 (seller's choice) a couple minutes before you posted. How do you feel about getting two of the three and leaving one for me?
I would like:
Photo #2, Item B, Item C, and Item D.
Please verify availability, and total, including shipping. I will follow up with a PM.
Thanks and have a great weekend!
Greg
Picture 3, O, P, fly cutters
Picture 5, K, Red, or black if not, L parallels
Picture 7, C, S&D Drills K Taps
No details on A1 & A2 live centers in first pic. May be interested if MT #2... but look to be bigger than #2 ?
Correct they are #4MT
After taking the picture I spun them... and it may have been the cold but they felt like the fresh oil I topped off turned to peanut butter... Not crunchy... just resisted turning. So Ill have to see whats going on before selling them.
I do happen to know where there is a no name Japan #2 MT with an aluminum cover you can reapply Loctite to reattach it. $25 Its smooth
Then there is a ROHM LIVE CENTER 102H MK2. new in the box with rust proof coating the previous owner applied to damn near everything I got from him.
How about $85 for the new one?
I'd like the p4 D step blocks, both pairs @$7, P4 chipped step blocks E @$8, and P8 M 200 da collets @ $60.
