FS: Jacobs drill chucks, LIke new Kant-Twist clamps, a few collets and 244 pictures of thing you can own.
Correct they are #4MT
After taking the picture I spun them... and it may have been the cold but they felt like the fresh oil I topped off turned to peanut butter... Not crunchy... just resisted turning. So Ill have to see whats going on before selling them.
I have some interest in at least one of these with #4 taper when you look into them. I need to check size and condition of what I have....
I kant either... Right now
I have a commitment for the next couple hours... Then I will start working my way thru it all. In the next 4 or 5 hours I will update the list.
Can I get a bundle price for the rest of the kant twist items? After you figure out what’s going on thank you.
I'd like these.
K) Near new Sandvik s8-6-c3nf and 3 3/16" collets $20
O) Hefco stack blocks 1.52" X 3.03" x 2.21" $20 for the pair
Q) Single 1.38" x 1.96" x 2.34" $10
I think everyone has been contacted.
If you have not been contacted let me know. I apologize.....
Here is the second revision of the list
#1
C1,2) Jacobs #36B threaded 3/4"x 16 with key, .18 - .80 $40 each
D1,2) Jacobe 6A #2MT with key, 0-1/2" works could use more cleaning $25 each
F) Jacobs 32 with key 3/4" shank 0-3/8" $15
H) Jacobs 31Ba 3/8x24 threaded. $5 maybe new under the wax. Maybe not.
Near New Kant-Twist Clamps
1 pr 420 $65
1 pr 410 $45
2 pr USED 401 $15 each pair
#2
E) 3 arbors with cutters. the one with the letter E is welded. $15 for all of them
F) Valentine vsc-4125-6b125 With a 1" Weldon arbor $25
G) 16TPI thread comb $10
H) When I first saw this it was coated with wax. It looked like an R8 shank. My first thought was what Bridgeport could possibly turn this?
Futuremill wedge 60707-2 $30
K) Valentine ba-3.5-4r on a 40 taper $25
L) Royel tap holder 1" shank $15
M) 4 pieces 0-1/2 drill chuck, 1", 3/4, and 1/2" unknown mount. $25 for all 4
N) Taper 40 kwik-switch 300 master 804446,80351,80348, 80339 near new $150 for all
O) 1" arbor shank small end is 1" , large end 1.80" over 2.7" $10
#3
A) 2 Morse form tools new? $ 20 for the pair
B) Kennametal Kenlock LSR-5 $15
C) Enco missing one clamp $5
D) Valentine $10
E) 1" shank $8
F) Kennametal 3/4" shank $15
G) Valentine 1" shank $15
H) 2 3/4" dia 1" shank extra inserts? $15
L) 1 1/4" dia 4 1/4 long 10 inserts $25 (If this doesnt sell thats okay)
N) Darex cbn 2115 Are they junk or can y9u use them $15 for the pair
#4
C) 1" X 2" X 3 1/2"@ 5pair $5 per pair
F) 1 1/2" x 1 1/2" x 2 3/8" 2 pair & 3 chiped. $7 per pair $7 for the 3 chiped
G) $10 for 13
#5
A) Brown & Sharpe 788-360 without the collet clamp, two 1/4X 20 threaded holes 2 1/2" cubes $12 each
B) 5 pair 1" x 2" x 3" threaded holes $12 per pair
C) Dorian 73310102500 new $80
D) Fette F001 like new, 4X40 dies and misc $675
G) Brown & Sharpe 11-236-332 $25
R) new unused Vertex 5" X .30... 1.38" center to center holes 1.10" center
21, 23, 27, 29, 31, 33
37, 39, 41, 43, 47, 49 $25 for the pair
S) They can be anything you want them to be $5 for the pair.
#6
C) Southbend ?? Keith Rucker just made a spindle for its brother. Local pickup might be necessary $250
D) Dumore D2 needs a cord and base runs That 1/8" spindle almost went to a different project $50
F) Mighty Mini oil skimmer and fittings. Runs $225
G) For a smaller lathe maybe a 9c or the not to be mentioned 47!4$ Runs with a cord hooked up and needs a belt... $50
#7
A) 25+ counter bores $30
B) 29/32" with thru oil hole #3MT $ 15 for the pair
G) (1) 1 1/4", (3) 1 5/32" altered shanks $10 for all 5
#8
B&C) Objects that appear to be 5C collet fixtures. I didnt do well with them Your choice $7.50
E) Better makers 5C Collets $5 each
Royal 1/8", Rivet 3/32", 7/32", 15/16" Buck 1/2"
Hardinge 3/16", 3@ 5/16", 13/16"
F) China, Taiwan 5C collets $3 each
1/16" X2 5/16" X4 21/32"
7/64" 3/8" X3
1/8" X4 1/2" X2 3/4"
5/32" 13/16" X2
3/16" X2 9/16" 31/32" X2
1/4" X3 19/32" 7/8"
9/32" 5/8" X2 15/16"
1 1/16" 1 1/8"
G) 5 shop made collets that appear to be brass and steel 3c $20
H) Universal Engineering 90397 & 2 AcuraFlex collets $17
L) 20+ taping collets $30 for all of them. The wood block might be expensive to ship whole...
N) 1/4", 5/16", 2@3/8", 7/16",3@1/2", 5/8", 11/16", 7/8" 2.03 tall 1.37 dia $20
O) EA 6802K 1/4", 3@5/16", 3/8", 2 7/16", 1/8P $15 for all
p) AF11 collets [email protected], 3@2MM, 2.5MM, 6.5MM, 2@ 3/16", 1/4", 13/64" $20
S1) MHC 4" X 1 1/8" 09743402 $45
S2) SPI 3" X1" 71-473-3 $40
S3,4,5,6) MHC 6" X 1 1/8" 09743600 $85 each
S7,8) MHC 5" X 1 3/16 09743501 $70 each
I just gotta have:
PM coming,
Tenaya
