As usual I dont care about payment.... Mail me a check.... paypal ...what ever you wanna do works for me.
First dibs are awarded to the first post. Send a follow up PM and tell me how you wanna pay and Ill get you the necessary details.
Shipping.... Everything will be plus shipping....Im sending this via USPS flat rate boxes.... The cheapest rate possible....
Pictures of Misc
A 1&2) end mill grinding fixtures $5 each
B) 5C collet fixture FNL1008 24 divisions and everything $125
C) 17 R8 shaped objects $20 for all of them
D) Ral Mikes collet block set in a nice aluminum tray $50
E) 5 Weldon R8 end mill holders and a no name extra 1" Weldon 1", 5/8", 1/2" 3/8" 3/16" $60 for all 6
F) 1x2x3 block $5
G1) Suburban 1x2x3 boxed set $25
G2&3) Suburban 1x2x3 $15 each pair
H) 1x2x3 magnetic blocks $30 for the pair
I ) Collet stops 1,2,3,4,5,6,on 10 the end is brazed on Hardinge SS5c $ 13 each
I) Collet stops 7,8,on 9 the end is brazed on) $8 each
P) Hardinge J1 collets 1/4", 5/16", 9/16", 3/4" $20 for the 4
Pictures of Lathe tooling
A) [email protected] & [email protected] 1" new brazed carbide all for $35
B) 5 Carboloy AR-8 1/2" new brazed carbide $18
C) 5 Carboloy A-8 1/2" new brazed carbide $18
D) 5 Carboloy AR-8 1/2" new brazed carbide $18
E,F,G,H) 8 Used 1/2" brazed carbide $12
I) 7 nearly new 1/8" HSS $15
P) 5 Carboloy AL-7 3/8" new brazed carbide $18
Z) 9 new AR-6 7/16" brazed carbide $30
Pictures of Step collets
1A) ID about 2.377 $10
1B) ID about 2.937 $5
1C) ID about 2.660 $4
1D) ID about 2.661 $5
1E) ID about 2.228 $10
1F) ID about 2.220 $5
1G) ID about 1.979 $5
1H) ID about 2.121 $5
2A) ID about 1.570 $8
2B) ID about 1.570 $8
2C) ID about 1.680 $7
2D) ID about 2 $5
2E) ID about 2.036 $5
2F) ID about 1.758 $5
2G) ID about 2.034 $5
2H) ID about 2 $8
3A) ID about 2.023 $7
3B) ID about 2.012 $5
3C) ID about 2.067 $5
3D) ID about Aluminum 1.991 $5
3E) ID about 1.590 $5
3F) ID about 1.370 $5
3G) ID about Aluminum 2 $4
3H) ID about 1.533 $5
4A) ID about 2.216 $5
4B) ID about 1.699 $5
4C) ID about 1.5 $5
4D) ID about 1.731 $5
4E) ID about 1.562 $5
4F) ID about 1.76 $5
4G) ID about 1.733 $5
4H) ID about 16.31 $5
5A) ID about 1.515 $5
5B) ID about 1.773 $4
5C) ID about no name 3/4 hex $8
5D) 4 5c collets $10 for all of them
5E) Hardinge 5EC $10
5F) 2 Hardinge 5DS IDs about 1.26 & .944 $12 for the pair
6A) Hardinge 5ST 1" $6
6B) Hardinge 5ST 1" $6
6C)Hardinge 5C-SC 1" $8
6D) Harding 5C-E1 $8
6E) These fit a MT#3 socket, There is no thread in the shank. they are new unused poorly stored machinable expandable collets $20 for the pair
Pictures of Expandable collets
7) 7 expandable collets the last 2 on the right are unused. OD left to right is about 2.24, 2.21, 2.25, 2.188, 1.25, 2.610, 1.60 $40 for all of them
Some of these are labeled JFK, All have a screw in shank for a replaceable collet end.
8A) ID about 2.173 $12
8B) ID about 2.42 $12
8C) ID about 2 $12
8D) ID about 2.024 $12
8E) ID about 1.5 $12
8F) ID about 1.6 $12
8G) ID about 1.447 $12
8H) ID about 2.763 $10 stuck screw
For use with the shanks 8A thru 8H
9A) ID about 3.418 $5
9B) ID about 2.45 $5
9C) ID about 1.574 $5
9D) ID about 2.575 $5
9E) ID about 2.478 $5
9F) ID about 1.631 $5
9G) ID about 2.185 $5
10A) ID about 2.5 $5
10B) ID about 2.314 $5
10C) ID about 2.034 $5
10D) ID about 1.662 $5
10E) ID about 1.772 $5
10F) ID about 1.786 $5
12A) ID about 1.976 $5
12B) ID about 2.057 $5
12C) ID about 2.245 $5
12D&E) ID 2.5 unused poorly stored $10 each
5C collets
Most are stained, some have the sized marked with an engraver. In general they are used and poorly stored but usable collets.
Hardinge and Royal collets are $3 ea
All others are $2 each
Pictures of 1/16 to 3/8 5C collets
1/16 (A) Royal, internal threads (B) Harding ,Internal threads (C) Harding
3/32 (A) Harding ,Internal threads (B&C) Harding (D) No name, internal threads
7/64 (A) No name, internal threads (B) Harding ,Internal threads (C) No name, internal threads
1/8 (A&B) Harding ,Internal threads
9/64 (A) Fowler, internal threads (B) No name, internal threads
5/32 (A) Harding ,Internal threads (B) Harding (C&D) No name, internal threads
11/64 (A) Harding ,Internal threads (B) Harding (C) No name, internal threads (D) Harding ,Internal threads
3/16 (A) Royal, internal threads (B) No name, internal threads (C&D) Harding ,Internal threads
13/64 (A) No name, internal threads (B) Japan, internal threads
7/32 (A) Harding ,Internal threads (B) Japan, internal threads (C) No name, internal threads (D) Harding ,Internal threads
15/64 (A) Harding
1/4 (A) Japan, internal threads (B) No name, internal threads(C) Harding ,Internal threads (D) No name, internal threads
17/64 (A) Harding ,Internal threads (B) Harding
9/32 (A) Harding ,Internal threads (B&C) No name, internal threads
19/64 (A) No name, internal threads (B) Harding ,Internal threads
5/16 (A) Japan, internal threads (B) Harding ,Internal threads (C) Royal, internal threads (D) No name, internal threads (E) Harding
21/64(A) Harding (B) No name, internal threads
11/32 (A) Harding
23/64 (A) Harding (B) No name
3/8 (A&B) No name, internal threads (C) Harding ,Internal threads (D) No name, internal threads (E) Harding ,Internal threads
Pictures of 25/64 to 47/64 5c collets
25/64 (A) Harding ,Internal threads (B) Harding (C) Harding ,Internal threads
13/32(A) No name, internal threads (B) Fowler, Internal threads (C) No name, internal threads
27/64(A) No name, internal threads
7/16 (A) Harding ,Internal threads (B&C)No name, internal threads (D) Royal, Internal threads (E) Harding
29/64(A) No name, internal threads (B) Harding
15/32 (A)Harding
31/64(A&B) No name, internal threads
1/2 (A)No name (B) Harding (C&D)No name, internal threads (E) Harding ,Internal threads (F)Japan, internal threads
33/64 (A) Japan, internal threads (B) Harding ,Internal threads (C) No name, internal threads
17/32 (A) No name, internal threads
35/64 (A&B)No name, internal threads
9/16 (A) Harding ,Internal threads (B) Harding (C) Harding ,Internal threads (D&E) No name, internal threads (F) Fowler ,Internal threads.
37/64(A) No name, internal threads
19/32 (A) No name, internal threads (B) Harding
39/64 (A) No name, internal threads (B) Harding ,Internal threads
21/32 (A&B) No name, internal threads (C)Harding (D)No name, internal threads
43/64 (A&B) No name, internal threads
11/16 (A&B) Japan , Internal threads
45/64 (A) Enco, Internal threads (B&C) No name, internal threads
47/64 (A&B) No name, internal threads
Pictures of 3/4 plus 5C collets
3/4 (A&B) Harding ,Internal threads (C)Harding (D) Harding ,Internal threads (E) New So0kie , Internal threads (F) Japan , Internal threads (G) No name (H)No name, internal threads
49/64 (A) No name, internal threads (B) Harding ,Internal threads (C) No name, internal threads
25/32(A) No name, internal threads
51/64 (A) No name, internal threads
13/16(A) Japan. Internal threads, (B) Harding (C) Harding ,Internal threads
53/64 (A&B) No name, internal threads
27/32 (A) Harding (B) No name, internal threads (C) No name
55/64 (A) No name, internal threads
7/8 (A) No name, internal threads, (B) Harding ,Internal threads, (C)No name, internal threads
29/32 (A,B,C) No name internal threads
59/64 (A) No name , Internal threads
15/16 (A) Japan, Internal threads, (B) Harding ,Internal threads, (C) No name, Internal threads, (D) Harding ,Internal threads
31/32(A&B) No name ,Internal threads
63/64 (A) No name ,Internal threads
1 (A)Harding ,Internal threads, (B)Harding (C), No Name ,Internal threads, (D)Harding, (E) No name, Internal threads
1-1/32 (A)No name Internal threads
1-3/64 ? (A) No name, Internal threads
1-3/32 (A) Enco, Internal threads
1-1/16 (A) Kent, Internal threads (B) Hardinge, Internal threads
Pictures of Misc
F) 1x2x3 block $5
2D) ID about 2 $5
2H) ID about 2 $8
4C) ID about 1.5 $5
8C) ID about 2 $12
5C collets
15/64 (A) Harding
11/32 (A) Harding
15/32 (A)Harding
