FS - Surface grinding diamond wheels, hubs, pullers, spacers, wrenches
p-moon
Apr 2, 2005
indiana
Couldn't find anything to contribute today, but maybe someone can make use of these. If you don't like my price, feel free to make me an offer. Everything plus shipping, but I will be as good on ya there as I can be. Listing here before I dump them on eBay. Only posting a few pics, please email for more. [email protected]
1. Surface grinder hubs, all with left hand nuts. The ones with balance weights $55, each, the others $45
2. Removal tools for above $20 each
3. Wheel wrenches, $35, $25, $35
4. Grinding wheel blotters new, 1 1/4 hole, 10 for $2.50 including shipping
5. Cutoff wheel stabilizers, 1 1/4 bore, 5 inch O.D., 1/4 thick $20/pair
6. Grinding wheel spacers/washers. Most are heat treated and ground, 1/8 to 1/2 thick, 8 pcs total, $5 each or all for $30
7. 120 grit Norton corner cleanout / sidewheel grinding wheel with hub. Backside has a back angle dressed on it so you only need to dress the bottom to clean up the corner. Used it all the time for many years $65
8. 3 surface grinding wheels. I am nearly out of wheels, but came across these three the other day. All are used, but totally usable. The 220 is all but new, Norton 80 is about 6 3/8 dia, the Radiac about 6 1/8 and about .100 wide at the periphery. $20 for all three.
Over 22 years of owning the shop, we made lots of special cutters of all sorts, mostly carbide. Some were made on the Deckel, but the vast majority on a surface grinder with a punch grinder / whirlgig. We usually made three flute cutters because they were stronger than single or two flute and much easier to get the relief on than a four flute (There!! see, I did contribute today!!). These are the last of the diamond wheels that I had.
9. Diamond wheel on hub, 3 3/4 dia x 1.5 deep flaring cup wheel. I think 150 grit, diamond is 1/8 x 3/8, shows minor use $85
10. Diamond wheel on hub, 6 inch dia x 3/4 deep flaring cup wheel, a little more use, 180 grit I think, diamond is 1/8 x 3/8, $75
11. Diamond wheel on hub, 7 inch dia x 3/8 wide, looks like a 180 with 1/8 of diamond, nearly new but with a very minor nick on the corner. $90
12. Diamond wheel on hub. 6 inch dia x 1/4 wide. a 100 or 120 with 1/8 of diamond, also looking nearly new $85
pics of the straight diamond wheels.
Thanx for looking,
Pat
I would like the balancing hubs and a removal tool, 10 blotters, and the #9 cup diamond wheel.
Thanks,
Ken
re:
2. Removal tool for above $20
Do you know if the non-balancing hubs fit Boyar Schultz 612? If they do, I'll take them and one of ea. other items.
P.S. IIRC, BS 612 uses "standard" taper hubs with 1" dia at the widest taper opening, but I can be mistaken.
All of the hubs fit my grinders which were Mitsui and Gardner.
I will put orders all together and figure shipping and get back to you guys. Later today if I can.
Thanx,
Pat
Update on what's not spoken for:
1. Surface grinder hubs, all spoken for
2. Removal tools all spoken for
5. Cutoff wheel stabilizers all spoken for
6. Grinding wheel spacers/washers all spoken for
Diamond wheels on hubs all spoken for
Thanx to everybody for looking
