Mike RzMachine
- Feb 4, 2007
- Utah
FS 1991 Tree Journeyman 325 in Salt Lake City Utah
I’m selling my J325 to make room for a bigger machine. I’ve had a great experience with this machine, very capable for its age and size and has proven reliable in my use. It has box ways, Delta 20, DNC and helical interpolation. I’ve been programming it with HSMworks/Fusion360 and it works great with their Dynapath Postprocessor. DNC over RS232 has been reliable and makes the machine productive even with the limited memory. ZPS supports Tree machines, Dynapath still supports the control and the folks at both companies are very helpful. This is a great garage mill as it fits under a 77” threshold rolling on bar stock and runs from a 40A 240V circuit. I included scans of the installation drawing for size reference and some example parts, all steel, stainless and Ti.
My new machine uses different tooling so am selling this as a package including vise, a good selection of tool holders, compressor and the phase converter. When I bought this as a bare machine, I ended up spending more on tooling and support equipment than the machine and put together a nice array of tooling for mixed prototype work. All tool holders and studs are quality Mari, Redline, Techniks, Tegara (I use these for drills), Lyndex, Richmond. I’m also including two tools which massively improve on setup time, a Haimer 3d sensor and a Techniks tool setter. This is essentially everything you need minus cutting tools and a computer. I’m happy to give a quick run down of the work flow I came up with for setup and running parts.
$8500 for the package. Please contact by private message here.
I’m having a rigging company move this mill to their warehouse in Salt Lake City when they deliver my new machine. They can load on a truck or trailer for a reasonable price so you don’t have to coordinate your own riggers for pick up.
27” X Travel, 14” Y Travel, 6” Z Travel plus 16” Knee Travel
6000 RPM CAT40 Spindle, Rebuilt last fall, all new barden bearings with about 100 hours of spindle time since. Mist and compressed air nozzles that switch on with the spindle as needed.
Dynapath Delta 20 Controller, Supports DNC, Macros, Helical Interpolation, Jogwheel
All servo motors rebuilt with new bearings, seals, resurfaced commutator and new brushes, new drive belts.
Bijur autolube pump
Spare Controller, screen, keyboard, servo motor.
Tooling and support equipment:
American Rotary - Gentec 10HP Rotary Phase converter
Kurt D675 Vise with work stop
Edge CT40 Tightening Fixture
Techniks Pull Stud Socket
Techniks Tool Setter
Sierra Tool Racks – 20 places, plus a tilted shelf.
ER20 Collet Chuck, QTY 9
ER16 Collet Chuck, QTY 1
ER32 Collet Chuck, QTY 1 – this holds the Haimer probe
Endmill Sidelock, 1/4 QTY 1
Endmill Sidelock, 3/8 QTY 4
Endmill Sidelock, 1/2 QTY 3
Endmill Sidelock, 1", QTY 1
3/4 Milling Chuck, QTY 1
2" Mari Facemill with holder
Boring Head – nothing special here
Haimer 3D Sensor
ER20 Collet Set
Misc ER32, ER16 collets
pull studs
air compressor – 2 hp
Serial Cable
Bijur autolube pump
Haimer 3D Sensor
ER20 Collet Set
pull studs
Serial Cable
