rakort
- Apr 27, 2011
- Central Wisconsin
I understand using taper pins for their strength and alignment properties, but using them in addition to set screws makes the set screws obsolete. The threaded taper pins in this use also seem to be odd, as a normal taper pin would work just fine..... but I digress I am sure Monarch had its reasons.
How would get a normal tapered pin out? The threaded pin offers the opportunity to pull the pins out with the nut and without punch access to the small end of the pin.
