Fusion 360 post changes
DavidScott
Jul 11, 2012
Washington
This is a response to a post in another thread but I figured it should have its own vs hijacking the other. This is about the Fusion 360 Brother Speedio post changes to make the Z-axis move before rotation a property you can set in the post General dialog box. I/we are wanting to add this feature to a Brother post, preferably hi-fly-cncs on GitHub, so the Z-axis doesn't home every time you rotate the 4th. It would also be nice to do the same when using multiple WCS offsets as a separate setting.
Freds here on PM made changes to my Kitamura Yasnac post back in 2018 to add the settable Z-axis move to it, and it works flawlessly. I have attached 2 posts, one with and one without Freds changes so you can compare them to see the changes he made, there are a few extra changes that are not relevant. I had to change the files to .txt as I couldn't attach .cps files.
Below is the post box showing where you set the retract amount you want in retractoffset, what I think the relevant code changes are, and then a sample of the code this post posts. I can make some changes to the post but the changes needed are well beyond my abilities.
I merged 2 photos together so please note the space between the sections properties and function onCommand.
O1
G0 G17 G40 G49 G52 G80 G90 M11
M5
M9
G0 G49 G52 Z0.
(FINISH ANGLED FACE)
T3 M6 (.125 MILL)
G54
M11
G0 A340.
M10
M8
G0 G43 X-3.2897 Y.6209 Z.909 H3 G54 S6000 M3
G1 Z.859 F10.
Z.809
/HON
G41 X-3.2847 Y.62 D3 F15.
G1 G40 X-3.7103 Y.6208
/HOF
G0 Z.909
G0 Z2.
(FINSIH POCKET)
G54
M11
A0.
M10
M8
G0 G43 X-3.4006 Y.1918 Z1.6625 H3 G54 S6000 M3
G1 Z1.6125 F10.
Z1.2405
/HON
G41 X-3.4125 Y.2028 D3 F15.
G1 G40 X-3.5998 Y.1918
/HOF
G0 Z1.6625
M5
M9
M11
G0 G49 G52 X-10. Y-.05 Z0 A32.
M2
Hopefully this makes sense and perhaps this might be a handy thread to have.
  • kitamura J300 4th A32.txt
  • KitamuraJ300.txt
Looks like its posting that retract in the current WCS and using the tool length offset, does that mean you just measure the clearance value you want relative to Z0 in your Fusion WCS and enter that in your retractOffset?
If that could be enabled when jumping between multiple WCS that would be super helpful, hopefully Ed can include that into his Brother post.
