Fusion C axis milling
DBcooper
Jul 7, 2017
Kaufman
Trying to purchase a live tool lathe, and I wanted to write a program to test the waters a bit. I'm having trouble figuring out how to program C axis milling. Will this require the multi axis addition or is it just something I'm missing?
angelw
Sep 10, 2010
Victoria Australia
Look for a Lathe that has Polar Interpolation, programming will be a lot simpler, to the point were even complex profiles can be programmed with or without a CAM system.
Regards
Bill
angelw
Sep 10, 2010
Victoria Australia
The quickest way when you're not familiar with the use of Polar Interpolation is to ask if the machine has that option.
It's simpler because you program the tool-path as if programming in X and Y. The "C Axis becomes the virtual "Y" axis.
Regards,
Bill
ljeremy578
Aug 6, 2018
You can use a standard post for a Fanuc mill turn lathe. Biggest thing is tool orientation will determine whether you use a C axis or Y axis.
