Hello again!
I'm trying to engrave some text around the outside of a round part on a HRT210 4th axis in an early 2000ish VF7. I found a badass program on the internet somewhere wrote by a fella named Bill, something Haas should have done themselves! It lets you type all your text and gives you a total length of engraving based off a given text height, either that or an angles of rotation based off height and part diamater. With this info and the circumference of my part I'm able to position text equally around the diameter, in theory...
Here is what my code looks like, pretty simple stuff. Some stuff changed, but the relevant data is still there.
O00120
(O120 G47 S/N with G107 Wrap)
T6 M06
M03 S7500
G56 G90 G00 G17 G40 G80
X0.1 Y0. A0. (Start Point of Engrave)
G43 H06 Z0.1
G107 A0. Y0. R0.8 (R is Radius of Part)
G47 P0 (SOME WORDS SOME WORDS) X0.05 Y0. I-90. J0.075 R0.05 Z-0.005 F3. E1.5
G47 P0 (MORE WORDS, STATE) X0.05 Y1.9131 I-90. J0.075 R0.05 Z-0.005 F3. E1.5
G47 P0 (SIZE SIZE) X0.05 Y3.1564 I-90. J0.075 R0.05 Z-0.005 F3. E1.5
G47 P0 (SERIAL NUMBER) X0.05 Y3.8667 I-90. J0.075 R0.05 Z-0.005 F3. E1.5
G47 P0 (00-####) X0.05 Y4.1472 I-90. J0.075 R0.05 Z-0.005 F3. E1.5
G00 Z0.1 M09
G91 G28 Z0.
G90
G107 (Turn OFF Cylindrical Mapping)
M05
M30
For some reason this won't work properly. (SOME WORDS) engraves in place as programmed, but (MORE WORDS) engraves +90deg spaced from the end of (SOME WORDS.) From there it all seems downhill.
I've managed to run this exact code only on another slightly newer VF4, also with a HRT210. It works fine there. I've tried comparing parameters and searching google for more but can't come up with anything obvious.
Help, please!!
O00120
T6 M06
M03 S7500
G43 H06 Z0.1
G00 Z0.1 M09
G91 G28 Z0.
G90
M05
M30
Help, please!!
