Hello,
On a FANUC Series 31i-MODEL B control for an OKK Horizontal Machining Center, the values being passed in a G65 Macro Call Command are not going to the local variables that I am expecting. Below is the G65 line and the values in the local variable table after reading that command.
(After typing this out, I realized it comes down to the I & J numbers that I expected to be passed to #4 and #5 were put in #7 and #8, and the values that I expected to be in #7 and #8 (D and E), are missing altogether. All other variables were passed as I understand they should.)
G65 P3333 D1.0 Q.922 Z1.250 V12. T0.7 K7.0 R5.0 I50. J200. E3.0 A75.0 B85.0 C95.0 F0.0004 W58. S1000. (spaces added for clarity).
NO. DATA
00001 75.0000 (expected)
00002 85.0000 (expected)
00003 95.0000 (expected)
00004 DATA EMPTY (not expected - should have been the I-value - 50. - instead this value is in #7 (D))
00005 DATA EMPTY (not expected - should have been the J-value - 200. - instead this value is in #8 (E))
00006 7.0000 (expected)
00007 50.0000 (not expected - this should have been the D-value - 1.0, instead it is what should have been in #4 - I50.0)
00008 200.0000 (not expected - this should have been the E-value - 3.0, instead it is what should have been in #5 - J200.0)
00009 0.0040 (expected)
00010 DATA EMPTY (expected)
00011 DATA EMPTY (expected)
00012 DATA EMPTY (expected)
00013 DATA EMPTY (expected)
00014 DATA EMPTY (expected)
00015 DATA EMPTY (expected)
00016 DATA EMPTY (expected)
00017 0.9220 (expected)
00018 5.0000 (expected)
00019 1000.0000 (expected)
00020 0.7000 (expected)
00021 DATA EMPTY (expected)
00022 12.0000 (expected)
00023 58.0000 (expected)
00024 DATA EMPTY (expected)
00025 DATA EMPTY (expected)
00026 1.2500 (expected)
00027 DATA EMPTY (expected)
00028 DATA EMPTY (expected)
00029 DATA EMPTY (expected)
00030 DATA EMPTY (expected)
00031 DATA EMPTY (expected)
00032 DATA EMPTY (expected)
00033 DATA EMPTY (expected)
Any help would be greatly appreciated. If I figure it out, I will share what I found.
Thank you!
Best regards,
Mike M
NO. DATA
Thank you!
Best regards,
Mike M
