MazatrolMatrix
- Sep 27, 2015
Hi,
I'm wondering what the difference between those two is? The manual describe that G68 rotate the coordinate system through a new workpiece origin described using XYZ and then rotated around one of those using ijk with a given R value, to define a plane for the purposes of easy of programming. When I read Haas article about this for example, they describe it more like figure rotation around a given point. So I find it confusing.
Then when I read G68.2, it describes.. basically the same thing?
Is the difference that G68.2 is used along with G53.1 to align a B axis for example to be perpendicular with a given plane? And that G68 is rotating the coordinate system but is not used to align this plane necessarily with a swivel head? It's purpose is more about figure rotation?
But what if I rotate the coordinate system using G68, and then tilt B-axis to align with this plane, then what is the difference between it and 68.2?
Using an Integrex in my case.
