AccessDbGuy
- Dec 7, 2008
- Max Meadows, VA
Greetings,
I recently became aware of a local used machinery dealer that was offering a couple of used welding outfits, "one with tanks!" to quote them.
Its the first time I've seen them offer pressurized gas cylinders for sale in many, many years.
So I sent them an email suggesting they check the crown of the cylinder (curved area just below the valve) for the most recent hydrostatic test dates.
And then when I vistied them, that email led to a long discussion about potential liability for selling "expired, out of date" cylinders.
Generally, most refillable gas cylinders must be re-tested every five years. Some types/some gases are less (3 years), some more (up to 12 years.)
For details see: Cylinder Maintenance and Testing reuirements, for high and low pressure service cylinders. Code of Federal Regulations 49, Part 173.34. Department of Transportation. Cylinder and Valve requirements for maintenance.
If you have older cylinders around, grab yourself a piece of blackboard chalk and drag around the cylinder's crown. Then you may have to lightly wipe off any excess.
You should then be able to see previous testing dates stamped into the metal. If the "most current" date is more than five years old it means you should (1) for that type cylinder and gas, learn how long the valid testing period is and (2), if its "expired," either have it re-tested (and marked), or destroyed.
Keep yourself safe. Both from dangerous cylinders, and the other guy's lawyers.
Regards!
Stan Db
Regards!
Stan Db
