I'm trying to find out as much information as I can regarding the following inner ring gear on this slewring. I've contacted the seller as well as the manufacturer. Seller knows almost nothing. Manufacturer won't respond to emails. So I'm at a loss. Gear pitch gauges on Amazon are pretty expensive and I'm not even sure which gauge set to get.
The slewring is a 1/14 scale K970 Excavator Model Slewing Bearing.
I'd like to know:
Diametral or Module Pitch ?
Pressure Angle ?
From this calculator:
www.radiocontrolinfo.com
I put 108 into the Gear Outer Diameter (mm)
and 100 into the number of teeth
and I got 1.06 Metric Module and 24 Diametral Pitch
Is this math correct? Is it 24Pitch?
I'm trying to find a mating pinion gear (possibly a gear train) to drive this slewring so I'm trying to find as much about the slewring as possible. Would it be likely to assume a 20dg Pressure Angle on this type of Chinese metric gear?
I'd like to know:
Pressure Angle ?
RC Gear Calculator
RC Gear Calculator - The Metric Module and Diametral Pitch is Calculated by Entering the Outer most Gear Diameter in mm and the Number of teeth on the gear
