Joe,
I have a belt drive Boyar-Shultz 612 that I have taken
completely apart, and I think it is a smartly engineered
machine. Not at all a Yougo. I would call a Sanford a
Yougo, but not a Boyar Shultz. My machine had an oil
port on the front of the table. Right in the middle of
the tee slot for the table stops. I made a modification
to route the oil feed from the rear of the table. I used
an 1/8" drill bit soldered into a 3/8" extension rod.
I popped out the ball oiler 90° adapter elbow and drilled
the oil port out the back of the table. I tapped the hole
for 10-32 thread. This is a standard for small tubing
fittings. I was able to find a 90° banjo fitting to convert
from 10-32 thread to 1/8" push lock nylon tubing. The front
ball oiler elbow was replaced by a 64th size welch plug from
the auto parts store. With this feed line on the rear of the
table, I supported it with a rubber lined aircraft clamp and
ran the line to a Bijur lube pump.
I actually have 2 Bijur pumps. One for the table oil and one
for the column oil. I find red ATF allows the table to move
very freely, and I use Vactra #2 for the vertical column.
As for the rack gear, I bought a 16P and 14.5 PA gear from
McMaster Carr. I think it was a Martin gear.
McMaster Carr also has replacement bellows for the cross feed
screw. I remember them being $50 a piece or some high price.
But I bought them, because my grinder was nice otherwise.
I painted my Boyar-Shultz a deep red color, as I like how the
Van Norman grinders looked painted Red.
--Doozer
