shapeaholic
- Oct 14, 2003
- Kemptville Ontario, Canada
A very good friend has a contract to do some repair/restoration on the "historic" Watsons Mill in Manotic Ontario ( near Ottawa)
One of the many issues that need to be addressed are the worn/broken/loose/mis-shapened teeth on the drive wheel from the turbine to the shaft of the mill grinding wheel.
The setup is; 51"dia - 70 tooth wheel on the turbine shaft driving a 22"dia-30 tooth wheel on the grinding wheel shaft.
From what I can figure, the gears are approximately 1.4dp, with the teeth on the drive wheel being wood inserted into an iron hub, and the driven wheel being entirely iron.
One of the features that can be seen is that the teeth on the iron wheel have a reduced thickness (75%) and the wood teeth are increased in thickness (125%) undoubtedly to provide extra strength.
The wood teeth are "supposed to be" tight, and held in by a dovetailed arrangement, with some sort of tapered dovetailed wedges.
As can be seen this was poorly done during a previous restoration, and now needs some attention.
Can anyone help with some questions we have?
1) what wood should the new teeth be made of? I suspect the current are maple.
2) is the grain orientation important? what should it be ( dumb question but I gotta ask)
3) How tight should the teeth be in the iron wheel ( I suspect a slight drive fit, then wedged)
Sorry the pictures are not better, the lighting is a challenge.
Peter
Peter
