I'm looking for advice from anyone who uses reamers successfully on a consistent basis, that could maybe correct some possible misconceptions I have.
In my experience, using a reamer for production machining has always been a "last resort" or emergency choice. I have found them to be very unreliable in terms of producing a reliable size once you get below a total tolerance of .001". What I mean by that is during the course of a production run, you might have 10 parts in a row with the hole on size, then random outliers out of tolerance, and then more parts further in the run back on size. I also have had a reamer work out fine for one run of parts, then at the next setup a few months later, using the same part# tool from the manufacturer, it does not work out. I know these tools are manufactured with tolerances, but the variations in the feature sizes I have seen far exceed the manufacturing tolerances.
I also have found reaming to be unreliable for keeping a tight position tolerance, especially with modern GD&T where you may have .001 true position to 3 datums for a 2.00" length hole.
