Chip Turner
- Sep 7, 2011
- ohio
I have a Part that i'm qouting and the material is new to me, would like to know if anyone has experience with this stuff. what SFM, tool life, inserts yada yada yada to use /expect? anything you can help me with would be welcomed.
the material is:
30MnVS6 i guess this is the new number for it. it was 27MnSiVS6.
chemical comp: C.26-.33, Si .15-.8, Mn 1.20-1.60, P<.025, S.020-.060, Cr<.30, Mo <.08, V.08-.20, N .01-.02.
Application: this high strength Mn-V-based steel is a low alloy high grade steel with good machinability for controlled cooling from working heat (BY-treatment, condition +P according to DIN EN 10267).<german designation.
Applicable for automotive components as connecting rods, axle journals and wishbones.
i have done research on this and i guess that there is some "Ti" in it. now, that titanium in it is going to keep the nitrogen molecules close and if there is any excess heat i'm thinkin it's gonna make titanium nitride. what's gonna happen when i cut this with a Tin coated insert?..LOL
I will be performing un-interrupted turning and boring on a lathe removing approx. .060" per side of cut. there is no undercuts or weird angles so standard WNMG 432 is what i expect to rough with on the od and id. will finish with a DCMT on the id due to clearance issue on the back id angle. the part is cold forged.
the material is:
