noname777
- Aug 24, 2018
- NSW , Australia
that machine is monster. Looks like old T3 was retrofitted to be able to run MDS servo units.
Parameters are gone, FX board memory must be erased, made ZERO, with Laptop, like typical T2 re-initialization, before you can start typing original params.
T2 control issue is ....when memory is contaminated, you cant run the machine at all. Even if you manually type all params, machine get hold to invisible rubbish inside memory board, and will think god knows what of itself.
-C axis mode is only available once you homed C axis, engaged. So machine starts using servo control to operate C axis, and Spindle control to run your milling tool
-Tail stock can be interlocked with other axises or some other inputs, only way to troubleshoot it is , to walk through ladder diagram
