old_dave
- Apr 15, 2002
- Central Mother Lode, California
I'm trying to get the bottom off the apron on my 10EE in order to change the filter on the Bijur oil pump. First I couldn't get the bottom past the circular boss around where the rod for the electric leadscrew reverse goes into the thing (for want of a better term)on the lower right bottom of the apron so I loosened that electric leadscrew thing on the apron (which has caused another problem to be dealt with later). This in itself wasn't easy, I had to cut off the end of an Allen wrench to get at the socket head cap screws holding this on the apron. Once the apron bottom was clear of that, I found the rod prevents the apron bottom from coming down far enough to come clear of the oil pump. Do I have to remove the electric lead screw reverse control rod to get the apron bottom off or is there an easier way? If so, how do I do get the rod off?
