SVFeingold
- Aug 7, 2015
- Santa Clara
Try Henkel/Loctite 3035. Epoxy designed specifically for low surface-energy plastics like HDPE.
As always with adhesives, surface-prep is everything. At minimum I would hit the surface with an abrasive to remove any embedded dirt and then clean with IPA + a clean, lint-free wipe.
If you want to know the effect of sanding/cleaning/blowtorch/plasma/voodoo doll/magic beans/etc I'd make some test coupons if possible, and/or pick up some dyne pens to test the surface energy before/after any treatment method. Without testing/data it's hard to come down on one side or the other.
The Tech-Bond site is heavy on words and light on anything actionable like data or specifications. But solvent welding works after all, so assuming it's a solvent-welding process it's worth a shot for HDPE<>HDPE bonds.
