BagOfChips
- Nov 10, 2022
It’s that time of year for house keeping. We just finished cleaning out 3 of our Haas mills and it sucked as usual.
I have been shopping for a good sump cleaning vacuum for a while but I didn’t want one that took up much space. I also didn’t want one that leaked everywhere during change overs. I checked out every vacuum at IMTS and settled on the OilVac 130 from National Machine products. It has the ability so suck and pump at the same time, which empties the tanks quick. We just roll in a plastic tank and pump out the coolant directly into the tank. It cost us about 6k delivered.
After pumping out all the coolant you still have to get inside and scrub everything down. Even with a wash down hose and tank cleaner, it still doesn’t get off the gunk.
For the outside of the machines
We have always used Purple power, Zep, Citrus, Krud Kutter, etc.
For the inside of the machines
WD40 first to remove the gunk, then use degreaser for ceilings, windows, and other indirect coolant areas. To avoid contamination.
Rust preventative
Fluid Film or CRC SP-400
I kept thinking to myself that there has to be something better and faster, but I may be in denial.
I say all that to ask this question…
What is your go to procedure for cleaning your machines and what products do you guys use?
Also, I attached a picture of the new vacuum. It’s a game change for our shop.
Rust preventative
