Good/best quick connect air couplings
PeteM
Jan 15, 2002
West Coast, USA
There are about a dozen quick change pneumatic fitting types (Industrial, the similar V-style, Tru-Flate/automotive, ARO, ISO, Open Flow, JIC, Schrader, Lincoln, Compact, Universal, etc.) Several of them mentioned above.
If you want to sell an accessory that mates with one of these geometries, I'd be inclined to call makers and distributors to see which types have the highest market share. I'd guess "Industrial" and "Universal" but also see some of the others fairly frequently. If you're looking for a top notch maker as a distributor - same idea. Find out the market share, as well as the company's reputation for quality.
Garwood
Oct 10, 2009
Oregon
It's not about mating with the air connection. It's about attaching to the coupling externally. I want to market an air quick connect in a manner it has never been used.
Therefore the brand people prefer is more important to me than the style of the connector.
Looks like Milton and Parker are on top which makes sense to me. Thanks to all for sharing.
52 Ford
May 20, 2021
Around 15 years ago I fitted all my air tools and hoses with PCL quick couplers. They are a bit longer and last forever with a tight seal. But they are getting harder to find locally, as they were always a bit more expensive and the market has become much more price-sensitive. They were common in the UK but in the EU they are rare. The EU uses a DIN standard connector, and some countries use an Italian type. The three types are not compatible. What is the most commonly used coupler for air tools in the USA nowadays?
The most common style fitting that I see is 1/4" Industrial. If I buy an air tool and it includes an air fitting, chances are its a 1/4" Industrial.
Sent using Morse code on - .- .--. .- - .- .-.. -.-
country_boy
Nov 22, 2004
Alabama/Georgia
I use what ever McMaster is stocking in industrial interchange. Usually stick with the pull to connect. I suspect most people use whatever their supplier stocks. I count on MMC to filter out Harbor Freight crap. The female couplings are at least made in the US
Scottl
Nov 3, 2013
Eastern Massachusetts, USA
To clarify, I mean like these: Object moved
Not the push to connect tube fittings, but fittings for air tools.
Those are the Milton style and seem to be the most common. There are even swivel versions for tools that need the extra versatility.
I use a LOT of these. I've even put a female coupler on the front of a blow gun so I can attach different OD and length tubing for blowing out spaces such as moonroof drains, etc.
Brett W
Jan 10, 2014
Huntsville AL
Winterfalke
Mar 26, 2011
Huron
All the Milton branded couplers we have had have been pretty poor quality. I've been buying the Tru-Flate automotive style from Mcmaster and been reasonably happy with them. At work we've been getting Daisen Coupling fittings out of Japan, and they have been very nice to use. I have heard good things about Prevost, and I have a CEJN blowgun that I'm really happy with.
I will say, in my experience, that the cheap I/M style couplers that claim to be interchangable with both styles will pretty much always leak with either. Pick one and stick with it for the best results.
rons
Mar 5, 2009
California, USA
The style for "Automotive" is beefy at the tip. The "Industrial" is not. The only reason is that a beefy tip is needed because the guy under the car lift keeps dropping
the hose on the concrete. The Industrial guy doesn't have such greasy paws, and the floor probably has a few rubber mats to keep the tip from damage.
High-Flow fitting are what I would look at. Or make my own. Which I do.
Scruffy887
Dec 17, 2012
Se Ma USA
CEJN are the ones I use and they last longer than any other fittings I have seen. They make a bunch of different styles ad sizes. Quick couplings for compressed air | CEJN
I have some that are more than 30 years old now and still leak free.
Was introduced to Prevost awhile back. They are what all the NASCAR shops use.
PREVOST - the specialist in compressed air distribution and treatment - Prevost
Those are pretty pimp.
CEJN (Sain) is what I use. Just shove them in, no need to pull the foreskin back.
henrya
Jun 25, 2008
TN
Prevost looks really nice. I may try some.
steve45
Jan 16, 2012
Midland, Texas
Very good fittings, but pricey!
Quick Connects | Valves | Swagelok
Here's Milton's version of the Staubli safety style fittings....
Milton S-99705 1/4" NPT M-Style Female Push Button Safety Coupler | JB Tools
I like Milton the best for price/quality and availability.....they also seem to have a better design than some of the other manufactures, the connections take very little effort compared to others!
Kevin
I bought some of those Milton Push Button Safety Couplers years ago after one of our shop guys made the mistake of pulling an air hose across the floor. The coupler got caught on something, disconnected, and the hose hit him in the eye.
While the push button design sounds good, the Milton couplers SUCK! I can't remember if they wouldn't lock together or wouldn't come apart, but they were miserable to use. I returned all of them within a week.
