Graphite In Bronze Bushing
CPilz
New member
Our Customer has asked us to machine some large c932 bronze bushings with pitched ID grooves in them and fill it with graphite. Anyone have experience with that and is that something a novice person can do. I can purchase powder or paste but hardening it seems to be a road block. I've read this can be done with binders or heat treatment. The mating part is a steel shaft. The ID would be cut to size after the graphite is added.
magneticanomaly
Active member
Several companies do this...the name that pops into my head is "Graphite Metallizing" I do not know the process they use. I would call htem and maybe sub it out
thermite
Active member
Common stock item from MANY makers. Folk usually just buy them, ready-made. Here is but one example:
Plug Graphite Bearings | National Bronze Mfg.
24 hr turn around on quotes for specials.
And they have competition. LOTS of it!
Micmac1
Member
Your wasting time if you make these, your local bearing/bushing industrial supply shop knows the mfgs just sent them the RFQ, or a quick google search gives you the US mfgs, they even do customs with short lead times.
john.k
Active member
Also the Glacier high load run dry bushings ,quite expensive ,but used in exacting applications.
thermite
Active member
Prezactly.
Any fool can turn the Bronze.
But you do NOT want to know what amount of time.. and MONEY.. it could cost you to learn what THEY already know about putting Graphite to work effectively, reliably, and affordably.
