netsurferdude2
New member
I have been wanting a lathe for years and told my boss about it. He said that our sister company had a lathe that is not used anymore so I could buy it for $1 on the condition that I got it out of their shop.
I came home with a 2000lb Graziano Sag 12 as my first lathe. Sorta jumping in head first here.
My home shop does not have 3ph so the route to take is either a VFD or Rotary Phase Converter. I've read a ton on both sources of 3ph and used to install ABB VFDs at an old job.
My question is are there pros/cons to one source over the other specifically for the Graziano? I assume that going RPC, I would still use the clutches and speed switch the change speeds (and they can be somewhat finicky). Or the VFD would be used for speed control?
Since I paid almost nothing for the lathe, I don't mind spending up to $1000 for a RPC.
Any help or advice would be appreciated.
Picture when it was moved in:
