Greenerd arbor press stand mounting question
Andy FitzGibbon
Sep 5, 2005
Elkins WV
I have a Greenerd No. 3 arbor press with the factory cast stand. It's currently apart for repairs, so I stole a photo of an assembled one from the internet to illustrate my question.
Does anyone know why Greenerd left a big gap in the mounting surface of the base, in the area where the two mounting bolts pass through? The casting is pretty thin there, and so (predictably) someone overtightened the bolts on mine and broke the base through the mounting bolt holes. I can't see a good reason for building the base this way... wondering what I'm missing. Thanks.
Sent from my SM-G950U using Tapatalk
Rob F.
Aug 5, 2012
California, Central Coast
No idea why they would do that. Just be sure to add a shim on it so it wont happen again. I would set the shim plate on top of the stand and use screws to bolt it on either side of the crack.
Just a Sparky
May 2, 2020
Minnesota
I'm not sure why they did it, but mine's the same way - sans the crack. Might have simply been to reduce machine time.
As long as you don't smoke the bolts down on it, it should be fine once it's welded back together. Doesn't need to be terribly tight to do it's job.
