Kenre
- Apr 25, 2007
- Melbourne Australia
Working on a project where I will need to ID grind an oval ish shape, that will be hard chrome plated.
I'm fully aware of the grit issue, will have flood coolant. I'm thinking of building a box of sorts to contain everything into a self contained area as parts are only small. I will have a separate coolant supply within the box to avoid using the mill coolant.
Have 15000rpm spindle so should be usable. I can mount a diamond point within the box.
Not sure how I will go about programming for the wheel dressing and corresponding diameter reduction.
Luckily the final dimensions are not critical, + - .002 does not affect operation at all, just need a smooth surface
Any suggestions welcome.
