MiniMillMachinist
- Aug 30, 2022
Hello guys, I have contacted Haas about my problem, but in the meantime I wondered if I could gather thoughts on the problem I am facing.
When running a low chip load pass (I'm adjusting for chip thinning here) of 0.04MM/T or smaller, with my spindle running at 10K RPM in my Mini Mill, I'm getting weird surface artifacts that after my analysis appear to be the result of spindle, tool holder, or tool vibration. I have come to this conclusion because when I run the same chip load, but a spindle speed of 2K RPM, the result is much cleaner. If I run the spindle at 10K RPM, but with a 0.08MM chip per tooth, the result is again much cleaner, and the artifacts are gone, however now tool marks are evident (as you'd expect!), so I'd like to be able to run a low chip load at a high RPM with good results.
The passes are 0.2MM radial, 12MM axial, and I get the same result with any of my 3 flute or 2 flute cutters, and with all of my tool holders. For this reason I am doubting the tool holder being at fault, and in any case, this particular run was done with my YG1 hydraulic holder balanced to G2.5 at 25000RPM - I'd be really surprised if this was out of balance.
My tools all have less than 4 microns of runout at the tip, I believe this particular one was around 2-3.
Am I expecting too much out of this machine? I have paid a lot of money for it, and frankly the results I get from my much cheaper router spindle at 24000RPM with a similar chip load are much cleaner.
Any thoughts on this? I am aware the Haas spindles can be rebalanced with grub screws, so I'm hoping we can make progress this way.
