Hamer 3d Taster or haff-schneider?
mmurray70
Jan 11, 2003
Looking at buying a Haimer but I really dont like the fact that I need to pass the zero point twice to get on center. I feel like my workers will eventually find a way to go to zero once and then set the origin wrong. Has anybody made this mistake or is it not worth worrying about?
I saw this model from haff-schneider and you just go to zero and set it and done. I like this idea much better. But nobody talks about these? Are they as good as the Haimers? Where can I buy these? 3D Measuring Sensor Analogue | Haff & Schneider
Any others worth looking at? Is there a model from Haimer that works like this?
rklopp
Feb 27, 2001
Redwood City, CA USA
I see Tschorn for sale in the Travers catalog occasionally. I have a Haimer. I don't have other workers using it. I've never messed up the origin myself, knock on wood.
MaxPrairie
Jul 9, 2015
I have never had an employee only go 1 time around and set the zero incorrectly. They are more apt to try and go 3 times around and need a new tip. The Haff&Schneider does look like a nice edge finder as well, although the graduations look a little goofy as you approach the zero.
cb750chris
Dec 9, 2018
Prescott
I have the haff and schneider and it seems well made and works well. MSC sells it as an SPI but when I got it there's nothing that says SPI on it, just H&S. Saw it on sale for about 200 off recently also.
Sent from my SM-N960U using Tapatalk
Mtndew
Jun 7, 2012
Michigan
We have both. I prefer the H&S only because it allows you to get into tighter areas for probing than the Haimer does. The Haimer does offer a longer probe tip though.
Making a full revolution is actually safer in my opinion because it shows the operator just how close they are if they happen to be moving at a faster rate than a slow rate.
mmurray70
Jan 11, 2003
Yeah I considered that too. Haimer has bigger range of travel, for when the part sneaks up on you a little too fast. Thats a plus for sure.
But I really am liking the fact that the H&S has one zero point and thats it. One more possible failure avoided.
cmccull166
Mar 29, 2013
NW Pa
I just ordered a replacement Haimer from the one I crunched last week
:wall:
382.00 delivered from MSC .Maybe I should buy two?
Thats the best price I could find.
mmurray70
Jan 11, 2003
Think im going to try the H&F. I emailed them from their website and they sent me contact info to distributor in Canada right away. And they got back to me with price pretty quick. Only $493 CAD. Seems fair. Thanks to all that posted.
cgrim3
Dec 4, 2020
Baltimore
I contemplated this same purchase between the Haimer and the H&S. We went H&S. The H&S is great and is deadly accurate.
Look in Hoffmann Group catalog. From when I shopped around, they beat everybody's price for the H&S 3d tester
Homeshopblob
Apr 7, 2021
The H&S has plenty of travel. Approx 3/16" from rest to zero, and 7/16" of overtravel past zero. I have 2 H&S and a SPI version. Have yet to damamge one.
mmurray70
Jan 11, 2003
I got my H&S today. Nice little tool. No longer worried about the travel issue. You have a full 2mm (+/-1 on the dial) plus there is a little bit extra before and fair bit after the scale too. Should be fine.
Im glad I bought this over the haimer. The single zero point feature will be worthwhile for us for sure. Thanks to everyone for the advice.
Pete Deal
Apr 10, 2007
Morgantown, WV
Is that H&S taster graduated in any kind of meaningful increment? I have a Haimer and I use the fact that it's graduated in thousandths quite a bit. It's pretty often that I'm setting zero on some odd soft jaws to cut the back side off a part. Generally I will have a reference edge on the part, often .01 or so material left over so I will index off that. Other situations too.
mmurray70
Jan 11, 2003
Yes its graduated in .05mm increments. Close to zero point it has 0.01mm increments.
CNCtoolcat, I saw the Tschorn as well. Looks like nice unit but it has same issue I didnt like with the Haimer.
segermech
May 4, 2022
Can anyone tell me if the tip on the Haff is magnetic material like carbide? We use magnets for clamping here and the Haimer's carbide tip is acting crazy when we use it.
Mtndew
Jun 7, 2012
Michigan
Yes it is magnetic.
They may offer non magnetic tips. I'd check their website.
